586,094 active members*
3,951 visitors online*
Results 1 to 10 of 10
    Jan 2017
    52
    Lightbulb Mach3 Window Question?
    All You Mach3 Gurus in Cyber Land.
    When I first started trying to work with Mach3 the Toolpath window was fine. Now that I am trying to cut a Guitar Body it is so small I can't see it.
    I can't figure how to enlarge the Guitar in the window.
    My next issue is : Cutting the top of the Telecaster body everything looked great until it cut the Control Slot.
    It cut it on the wrong side of the guitar. Which would make it great for a left hand picker.
    The guitar in the tool path window is facing the opposite direction as it is on my Router machine.
    I'm sure these are simple solutions to you guys but I'm just trying to learn this stuff,,
    And it ain't easy teaching an old dog new tricks,, :-)))
    Thank you for your input.
    cubs
    Re: Mach3 Window Question?
    Zoom in with the mouse wheel I think?
    If the tools current position is far from the g-code location, it will appear smaller.
    Whatever axis is cutting wrong is setup backwards.
    Jan 2017
    52
    Thank You,,
    Going to do some Recalibrating this morning and see what I have.
    cubs
    Jan 2017
    52
    Okay fellers,, I'm as lost as a ball in high weeds,, Beating my head against the wall and I know this should not be this difficult.
    My machine is Home Built first of all.
    The Spindle is on the X Axis and "Plus" Movement is to the right. Zeroed at position all the way to the let.
    The Y axis is actually the Part being machined Moving on the table Moving Away and to the Back of Machine is "Plus" . Zeroed at Front of machine closest to operator
    The Z Axis is Zeroed all the way up in a "Plus" Direction Minus direction down toward the work.
    Now, I'm trying to cut a Guitar Body. I Put the Material on the Machine and secure it.
    Load the G-code Zero to the edge of material that the Code Shows on the screen.
    The image of the Guitar in the Tool path image shows the Neck cutout straight up on the screen.
    The Slot cutout for controls it shows on the right side.
    If this would Run the same way that it is showing it would be PERFECT..
    BUT it moves the material to the Opposite end to cut the Neck slot.
    And By it cutting the Control Slot where tool path shows it on the screen it is now a "Left Handed Guitar"
    And That won't work for me.
    I'm totally lost here. I don't know how to Reverse the image in Mach3 Or Lazy cam.
    Would be glad to send this operation of the Gcode for you gurus to look at. Or perhaps someone knows how to correct this.
    But I've been trying for over a week to figure this out.
    Thank You very much,,
    Cubs
    If the Y is a moving table, you have it backwards.
    Jan 2017
    52
    Does that mean I need to Reverse the Y motor Driver?
    Thank you,
    cubs
    You can just check the Reverse box in Config > Homing/Limits.
    Jan 2017
    52
    Thank You so Much,, That Worked Perfectly, It has about drove me crazy,
    Hope you have a wonderful weekend.
    cubs
    Nov 2007
    361
    Quote Originally Posted by cubby View Post
    cubs
    Did you ever get this figured out? Ger21 said it there is a button in ports and pins reverse the axis
    Jan 2017
    52
    Cool Re: Mach3 Window Question?
    cubs
    My problem was that My X and Z axis moved my tool, But my Y axis DID NOT MOVE THE TOOL,
    The WORK MOVED In The Y-Axis Mode, Thus the Tool Was STILL and The Table Moved,
    I Build the Mill and the Controls and Everything on this machine, And it Works great Now,
    Built some Beautiful Guitar Bodies, But instead of the Pins in the Software I Reversed the Plus and Minus on The
    Y-axis Driver Board, Worked for me,
    cubs
  1. Replies: 7
    Last Post: 05-07-2014, 04:56 PM
  2. Question regarding post-processing window
    By declanhalpin in forum MadCAM
    Last Post: 05-09-2013, 08:45 PM
  3. Dumb AutoCad Question (Open window won't come up)
    By MaxxMan-X in forum Autodesk
    Last Post: 02-28-2011, 08:16 AM
  4. Beginner question (search in code window)
    By Bigbloke in forum Mach Mill
    Last Post: 09-19-2010, 11:35 PM
  5. mach3 display window
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 08-10-2009, 03:00 AM
