586,061 active members*
4,504 visitors online*
    Jul 2012
    18
    Fanuc Ladder not logical
    Hi All,
    UI am wondering is someone can help me with this. We have a Vtech milling machine That has an alarm. Looking at the Ladder R1646.2 is on. But when I look at the logical ladder R9000.1 is off so R1646.2 should also be off. I did look for duplicate coils but there is nothing. Can someone tell me what is going on here?
    Dec 2009
    953
    Re: Fanuc Ladder not logical
    where is going that R1646.2?
    might be reset it by a Keep relay.
    can you upload the ladder?
    This is a bit to understand but R9000.1 is on. The rung doesn't show it as it is the result of the function block directly above it.
    R9000#1 :Negative (input data<data compared) The input data is D920 and the compared is D3040. You will have to find out what the are ref to on your machine.
    Jan 2014
    106
    It drives me crazy the way fanuc uses those R9000.0, R9000.1, R9000.2 bits. I wish the function blocks just output directly from them instead of utilizing the R9000 bits. Simply because R9000 are used multiple places after each block they are associated with. And most of the time, which you experience here you don't see the true "state" it is in. Sometimes I will have a coil that's highlighted and the R9000 bit and rung will not even be on
  1. Replies: 7
    Last Post: 04-11-2018, 03:57 AM
  2. please, how to use NOT ( logical negation ) ?
    By deadlykitten in forum Okuma
    Last Post: 12-14-2017, 11:35 AM
  3. no logical home position
    By blakey235 in forum Fagor Automation
    Last Post: 07-13-2014, 04:32 PM
  4. Fanuc 18iM, logical AND
    By Mika M. in forum Fanuc
    Last Post: 05-11-2010, 10:03 AM
  5. ladder fanuc om-a
    By rathi_vk in forum DNC Problems and Solutions
    Last Post: 01-11-2009, 08:34 PM
