586,117 active members*
3,310 visitors online*
Results 1 to 15 of 15
    Jan 2007
    626
    NPN Proximity Switch Extension Cable
    I bought some Proxs off Ebay to try as limit switches, but the cables are too short.
    The conductors are 0.1mm sq, 3 cores, brown, blue and black. ( Standard colours for Prox Probes )
    I'd like to keep the conductor colours the same to prevent confusion.
    I've been searching for days trying to find some...no dice.
    All the usually suspects, RS, Farn...sorry....Element 14, Jaycar, altronics, Digikey, Ebay. Even asked the Supplier...no meaningful response.
    Surely it must be available somewhere? Doesn't make sense.
    Anybody know where I can buy 25M roll anywhere?
    Steve
    Nov 2012
    1267
    Re: NPN Proximity Switch Extension Cable
    Solution #1: extend the cable in the middle so the end will have the original colors.
    Solution #2: buy different switches with longer cables (probably would be cheaper than buying cable from DigiKey).
    Solution #3: use a cable with different colors and make a note in the machine's paperwork.
    Solution #4: use colored heatshrink tubes to change the wire color.
    You should be using shielded wire on them anyways with the shielded wire soldered in fairly close to the sensor. Just make a note on how the colors correspond and move on.
    Oct 2004
    178
    buy prox cables from Automationdirect ( they're cheap) cut the plug off, solder and heat shrink and you're done. Colors match
    Jan 2007
    626
    Thanks Guys,
    Don't really want to repurchase any more, so will use another solution.
    The Proxi's didn't come with shielded cables, so I assumed they didn't need it.. It makes sense that they should though.
    Nov 2012
    1267
    Quote Originally Posted by Sterob View Post
    The Proxi's didn't come with sheild cables, so I assumed they didn't need it.. It makes sense that they should though.
    No, they should not. Most proximity switches - not just Chinese ones, but brand names like Telemecanique/Schneider - have unshielded cables. Using 24V logic gives you enough noise immunity without shielding.
    Jan 2007
    626
    Quote Originally Posted by CitizenOfDreams View Post
    Makes sense...thanks.
    Apr 2005
    23
    Those NPN proximity switches on eBay are around $2 or so right? 10 for $20. Could just buy a couple more if you didn't get extra ones, cut off the wires from another one or two and extend the one you are using, same wire.
    I have the Chinese ones and I had issues with them until I shielded them. I use 30V by the way.
    Also if you do go the Chinese route and have coolant then make sure you get potted ones. The other ones don’t hold up well in coolant.
    Jan 2007
    626
    Quote Originally Posted by minitech cnc View Post
    A couple of them may need that done twice...hard to say at this point.
    Jan 2007
    626
    Quote Originally Posted by CL_MotoTech View Post
    hmmm...ok. I better keep that in mind.
    Maybe I should just cut the whole cable off and fit shielded cable from the start. So much for usin gthe KISS principle....lol
    - - - Updated - - -
    Yes, they are potted....At last that is ok...
    1943
    I have the chinese potted prox switches on my machine and I used the unshielded cables that came on them and they work fine on my machine. No issues whatsoever.
    Jan 2007
    626
    Quote Originally Posted by 109jb View Post
    Ok...maybe the potted switches don't require shielding?....dunno.
    Seeing as I have to extend the leads anyway, I may just buy shielded cable and repalce the lot.
    Jan 2007
    626
    Decided to err on the side safety and use screened cable ( thanks gents )
    Gave up on trying to find the correct colours and just went with the right gauge.
    I'll join the cable at about 100mm from the Prox to maximise the screening.
    This means I'll need 24 pins for connector at the control box. ( 6 x 4 ) Lucky I have 25 ( DB25 )
    Steve
  1. NPN Proximity Switch
    By kolias in forum CNC Machine Related Electronics
    Last Post: 08-05-2016, 07:04 PM
  2. Heidenhain Encoder Cable Extension
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 02-20-2013, 06:50 PM
  3. PCMCIA Extension Cable
    By gregfull in forum Want To Buy...Need help!
    Last Post: 05-31-2012, 11:48 PM
  4. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  5. IDE and floppy drive extension cable
    By Karl_T in forum Computers / Desktops / Networking
    Last Post: 11-17-2005, 07:59 PM
