603,795 active members*
2,948 visitors online*
Hybrid View
    How to make alive my pneumo-relay
    Please help!
    I dont understand - how to make alive my pneumo-relay.
    I have KFLOP + Konnect Optical I/O Expansion Board.
    Pneumo-relay connected to Konnect pins Out 12, 13, 14, 15.
    In the Kmotion -> Digital I/O -> Virtual, I see flags opposit connected pins.
    In the KmotionCNC -> M100-M119, I set I/O Bit. That is all.
    What to do next?
    I need commands in G code to turn on and off relay:
    M100 turn on relay pin12.
    M101 turn off relay pin12.
    M102 turn on relay pin13.
    M103 turn off relay pin13 (and so on, to pin15).
    How to do it? - in order Konnect understand G code ond do on/off relay
    May 2006
    4089
    Re: How to make alive my pneumo-relay
    Hi RuslanRobot,
    I don't understand. If you toggle Virtual Bit 60 on the KMotion | Digital IO | Virtual Screen does the Pneumo-relay toggle on and off?
    If so, this is how you might configure your MCodes:
    Attachment 421524
    Please remember to put reverse flyback diodes across any solenoid or relay coils.
    TK
    http://dynomotion.com
    Yes!!!
    I did in accordance with your screen shot, and I can turn on/of lights on the board by G-code (M100 - lights on, M101 - lights off).
    But I connected relay to the Konnect without flyback diodes and relay doesn't click.
    Is it mean that I burned out all board Konnect, or only pins 12 - 15?
    May 2006
    4089
    Hi RuslanRobot,
    How did you wire it? The Konnect outputs are like an isolated switch contact. You must have a power supply to apply power to a relay. Also the outputs will only conduct one direction like a diode.
    The Output circuits are all optically isolated so damaging one is unlikely to damage another.
    TK
  1. using mach 3 to make wire edm machine come alive again
    By ahmed sarhan in forum Mach Wizards, Macros, & Addons
    Last Post: 03-04-2025, 01:29 PM
  2. It's Alive!!!
    By mcphill in forum Mikinimech
    Last Post: 02-06-2011, 04:02 AM
  3. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  4. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  5. Its Alive
    By debogus in forum DIY CNC Router Table Machines
    Last Post: 03-10-2005, 03:05 AM
