586,115 active members*
3,476 visitors online*
IndustryArena Forum > CAM Software > Vectric > Corner Probing Routine
    Apr 2005
    1268
    Hey Guys and Girls;
    Is there available a probing routine that will allow one to probe the (for instance) lower corner of a rectangular piece of stock and the upper right corer to assure that the outer boundaries are square? I do a bit of simple name plates on a 5.5 X 24 pine board and usually finish the corners on a manual talbe just to make sure that they remain true. If mounted on the table (without a jig) one takes a chance of the stock being slightly off square which would make the outer boundary finish to be off kilter when not exactly square to the machine.
    Hope this makes sense. Also I use Aspire so the reason for my question here.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Apr 2005
    304
    Cool Re: Corner Probing Routine
    You definately need a jig, or at least an "L" stopwhich is inline with your X and Y axes.
    Another way is to calculate your stock rotation (math ) and to set your CNC software according.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jun 2018
    84
    I've attached a picture of my XY axis locator. It also is a tool height setter. Pictures attached. Is this what you are looking for? If you are interested I can send you the script language.
  1. Help with probing routine
    By kdunph33 in forum Haas Visual Quick Code
    Last Post: 09-05-2019, 06:49 PM
  2. Probing Routine Using ITTP
    By smokediver576 in forum Tormach Personal CNC Mill
    Last Post: 02-11-2019, 12:16 AM
  3. Probing Routine - Haas/Renishaw
    By amphib in forum G-Code Programing
    Last Post: 04-28-2018, 01:35 PM
  4. Fast Probing Routine/Wizard/Setup?
    By Bob La Londe in forum Digitizing and Laser Digitizing
    Last Post: 06-30-2013, 05:14 AM
  5. Heidenhain Probing Routine
    By nigel2000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2012, 01:50 PM
