Re: Vetric Aspire nose dive on Z Axis
Originally Posted by
Ntl
Oh I kinda thought it was a router but you posted in a laser engraving forum. Can you post screen shots of the Aspire file showing the tool path info along with the part rendering? Btw the feeds and speeds are in the tool setup in Aspire. You need to make sure you have the proper chip load for your tooling setup, the default settings more than likely won't be right. Is it a 3d machined part.? You might want to start a thread on vectrics forum if you are only having issues making parts with aspire. Have you machined similar parts with Mastercam with out issues?
Ditto, we had over 20 pages posted on the Vectrics Forum a few weeks ago and it ended up being mostly user error. Just about exactly the same thing as here. User did not understand basic CNC flow pattern or G Code and we spent a lot of time on his issue.
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
