586,121 active members*
3,661 visitors online*
    Question Controller Wiring Type
    I assume all internal controller wiring should be stranded to handle any potential vibration?
    I'm thinking for simplicity I'd use all 18 AWG for everything except the mains and router etc.
    Are twisted pairs and/or shielding needed for wiring between the step controller and stepper drives over relative short distances?
    Re: Controller Wiring Type
    You'd normally use MTW wire for the control box.
    18 awg is much larger than needed for low voltage and step/dir wires.
    Only if you are using differential signals.
    18 awg is much larger than needed for low voltage and step/dir wires..
    I know. My thought was to use a jacketed 4, 5, or 6 conductor wire and use the same wire for the stepper motors that are stationary. It seemed that any twisted or shielded wire was cheapest by the foot at 18 AWG. I assume its a volume manufacturing thing.
    I'll investigate the MTW, honestly never though of that. Trying to keep cost to a minimum.
    You can probably use 20 or 22 gauge for everything.
    500' of 20 gauge MTW wire is only about 20 bucks.
    24221
    For control enclosure wiring it is definitely customary to use stranded conductors, there is TEW/MTW etc, but if packing a lot of conductors in a raceway, I use TR64 control wire, the insulation is not so heavy as the other two, but still retains the voltage insulation value.
    Al.
    Albert E.
  1. what type of motor controller to buy
    By sledhead306 in forum Benchtop Machines
    Last Post: 05-25-2017, 02:55 PM
  2. New Multi Type Motor Controller
    By smarbaga in forum Open Source Controller Boards
    Last Post: 03-13-2015, 12:44 AM
  3. Multi Type Motor Controller
    Last Post: 02-25-2015, 05:55 PM
  4. Servo controller type where to get this.
    By helliman 27 in forum Benchtop Machines
    Last Post: 08-22-2014, 06:15 AM
  5. 5 motors, 4 axis, what type of controller can do this?
    By avengine in forum Community Club House
    Last Post: 05-06-2006, 04:37 AM
