586,075 active members*
3,967 visitors online*
Results 1 to 16 of 16
    Aug 2010
    686
    Trying to find this connector
    This is a cable connector that came with my square 1.5Kw spindle. I need to find a replacement connector so I can make a new cable.
    Attachment 422954
    The cable connector connects to the female located on the spindle.
    Attachment 422956
    If anyone knows where I can get this connector, or even what this type connector is called so I can do some searching.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    ericks Guest
    Re: Trying to find this connector
    I have seen some sold on a chinese site, can't remember atm. Mine i bought recently from Lapp, the guys that supply cable, but the "genuine" good quality one's from Lapp and Rs components are quite expensive.
    Think i paid around $50 AUS, for the complete male and female
    ericks Guest
    I just had a look at the Lapp site...here the plug is around $20 AUD, you do have Lapp in America
    Hope this helps
    Aug 2010
    686
    Link?
    I would pay $20 for the male plug. My other option is to take the original connector off the cable it is on and make dongle that connects to a more common connector.
    Oct 2004
    94
    Quote Originally Posted by msimpson99 View Post
    Link?
    With a bit of googling...
    https://lappusa.lappgroup.com
    Apr 2016
    841
    Try this link: https://lappdigitallibrary.cld.bz/LA...og/301/#zoom=z. It's to the North American catalog (and the site).
    ericks Guest
    Looks like you all sorted now
    Aug 2010
    686
    Looks like it is an HA 4 connector. Searching on Ebay I was able to get four (used) connectors with housings delivered for under $50.
    Thanks again for the help.
    Feb 2007
    4553
    Post Re: Trying to find this connector
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    ericks Guest
    Apr 2016
    43
    This looks like a Harting connector, https://www.elfadistrelec.no/Web/Dow...6/04347126.pdf
    Apr 2016
    43
    I am a industrial electrician by trade and reading people writing that metal connectors do not cause fire makes me wounder where they get this claim from. I have seen die moulded aluminium connectors melted from earth faults, blown wide open from series arcing over time. Sure, I would feel much safer about metal style connectors but saying they do not cause fire is upright wrong.
    Feb 2009
    6028
    Quote Originally Posted by oscilloman View Post
    Technically, they don't cause fire, the shorting does
    Apr 2016
    43
    Quote Originally Posted by underthetire View Post
    Yes, shorting to the metal housing, I just wanted people to know that connectors made with metal housing do at some occations make really hot sparks as well. But sure, if it is on your own hobby mill, and you are not running lights out I would not be afraid to use a noname connector from china.
    Jun 2008
    467
    wmgeorge,
    I am a master donut maker not a Master Electrician like you and would like to know how you determined the current capacity, internal resistance of the terminals, dielectric material, voltage failure or breakdown rating and thermal properties of the connectors jalessi posted just by looking at a picture and not using any type of test equipment.
    Please educate all of us less informed apprentice hobby electricians that don't have x-ray vision.
    Live from downtown L.A. home of the relentless Cup-O-Joe
    Joey B
    A doughnut a day keeps the doctor away.
    Mar 2013
    88
    I work in a power plant, we have metal 480v 3 phase 100amp welding plugs all over the place. They are all metal bodies.
    We also use metal Amphenol plugs on tons of control wires.
    Don’t mangel the pins and make sure you have proper insulation and strain reliefs, metal plugs are fine
    Sent from my iPhone using Tapatalk Pro
  1. OP connector sanyo denki servo PV drive - looking for connector
    By gm276 in forum Want To Buy...Need help!
    Last Post: 12-15-2018, 07:39 PM
  2. connector pinouts for the tnc 320. Can't find a TNC 320 Technical Manual
    By amtekinc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2017, 10:32 PM
  3. JP5 connector
    By CAROLIVAR in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-26-2011, 09:32 AM
  4. Need connector
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 07:26 PM
  5. Help find terminal connector type for this stepper
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 10-09-2004, 07:34 PM
