586,077 active members*
3,648 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > isolated power for parallel port optocouplers
Results 1 to 8 of 8
    Jan 2007
    44
    hey guys,
    I'm trying to create a totally isolated parallel port drive interface circuit for a particular machine.
    I want to use optocouplers for both inputs, and outputs. Outputs are fine, low power optos run directly off the data lines. The problem i run into is the inputs to the PC.
    So, i have 2 questions:
    1. I notice that several of the input pins are labeled "inverted" and some are regular. Do i have to drive them high, or low or some mixture of each?
    2. How can i get power to drive the inputs to the PC high, while remaining totally isolated, without using an external battery? I was thinking using an isolated DC-DC converter 5V in, 5V out, and connected to the machine 5V logic line. Would that give me the isolation i'm looking for? any other way to do it? DC-DC converters are kind of pricey, kind of large, and i'm not swift enough to design my own.
    Jul 2005
    2415
    All you need is a small ac transformer (18 VCT gives you 9 VAC off the CT and one leg), 250ma to 1A rating; a small 1A or 1.5A round bridge and a 1000mfd @ 25VDC (or higher) filter cap. Feed a 7805 with a .47 mfd across the output and you have the "floating supply". It's ground return is not connected except to the circuit on the input of the opto side.
    Since most noise comes across via the common ground connection getting true isolation requires a separate source of DC. A DC-DC converter only works if it has a transformer and is isolated. It is the most expensive way to go if any current at all is needed.
    Another really cheap option is to buy a 5VDC wallplug transformer. It doesn't even need to be exactly 5VDC. You just figure the current limit resistor in series with the opto input emitter based on the DC voltage in the circuit.
    tomCAUDLE
    www.CandCNC.com
    BOB's
    Digital THC
    Complete Electronic Packages
    Stepper & Servo Systems
    Hand Controllers
    Jan 2007
    44
    I wanted this thing to be totally self-contained. No power packs, no external cords, etc... The only power I have available inside the machine at the interconnection point is the +5vdc logic supply, and the parallel port can't provide any power of it's own. (Why didn't they just include one 5V pin???) Since the power from inside the machine is already DC, the suggestion above won't work.
    I really don't need much current at all. Just enough so that the PC sees a logic high.
    Some of the DC-DC converters are isolated. Looks like they chop up the input DC, effectively turning it into AC, and run it across a transformer, and filter it back to DC again
    I'm just looking for a completely isolated connection. Input and output. Would i be safe with just a direct connection? Probably, but i'd rather be safe, and account for every possible mode of operation and failure, than have a fried pc.
    Aug 2006
    2758
    Quote Originally Posted by mike944 View Post
    Some of the Analog Devices' isolators from the ADUM1400 series have a DC-DC converter included into the chip, some have input and output going channels.
    Jan 2007
    44
    That's a very interesting device. I may use that instead of my optocouplers. I wish it wasn't surface mount though. Oh well, i guess i can't be too picky
    Jun 2003
    3312
    What kind of signals are you wanting for your inputs? If they are mechanical switches and the connections and contacts have no conductivity to anything else, they are already isolated, no need for anything.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jan 2007
    44
    Closed switches come out of the control distribution board as +5v, which is tied to the machine supply.
    Jun 2003
    3312
    Then if you want to be isolated you will need either opto's or other isolators.
  1. C++, Win XP, Parallel Port
    By Zumba in forum Coding
    Last Post: 03-29-2012, 07:12 PM
  2. 220/100 Volt non isolated power suplly for step motor drivers
    By bunalmis in forum CNC Machine Related Electronics
    Last Post: 03-30-2007, 04:36 PM
  3. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
  4. Electricity isolated from power-grid?
    By medved in forum Waterjet General Topics
    Last Post: 03-16-2006, 01:28 PM
  5. Parallel port
    By Aldoseri in forum BobCad-Cam
    Last Post: 03-13-2006, 05:10 PM
