586,115 active members*
3,429 visitors online*
Results 1 to 11 of 11
    Nov 2017
    4
    make Lathe tool holders
    Hello Everyone.
    I want to make some lathe tool holders for a 8 position turret lathe . My problem is finding material. I would like to make them out of 4140 just because I have seen others on the web use it for similar things.
    The material would have to be solid square or similar . Approx 100mm x 100mm by 120mm long. I have googled and called few companies with no luck . Any contacts for material or even suggestions for a different material would be great.
    I am on the east coast of Australia half way between Sydney and Melbourne so freight is similar either way.
    Thanks.
    Dec 2013
    5717
    Re: make Lathe tool holders
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    4
    Thanks Jim.
    They have what I need.
    Dec 2013
    5717
    My pleasure to help. :cheers:
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2010
    4256
    According to Firefox, that buau.com.au web site is a serious security risk. Not going there.
    Pity: Bohler (same thing) has a lot of good steel.
    Ring them instead? They have a good paper catalog.
    Cheers
    Roger
    Sep 2018
    35
    The only problem with their site is that they use their main SSL certificate for their encryption, that is registered in their main domain www.bohlercolombia.com, both sites are hosted on the same server, it throws the error because the domain is buau.com.au is not the one listed on the certificate which makes it invalid for the certificate, the site is not harmful
    Jun 2010
    4256
    That may be so, but it implies that their web bunnies (or server admin) are incompetent, which means that the site could become a security risk from hackers seeking targets. It also means they are going to lose quite a lot of potential customers. Not clever.
    Cheers
    Roger
    May 2015
    686
    Really, Bohlers is not the kind of place you can buy on line so why get stressed? I have a feeling that is an old website and they changed their name as sometimes global companies do. But at least you have found the information you need so give them a call and work it out from there.
    Rod Webster
    www.vehiclemods.net.au
    Jul 2009
    152
    I use Bohlers all the time never had any problem with them or their site.
    Warrrenkcash what type of tool holder are you looking at making?
    Nov 2017
    4
    Quote Originally Posted by Rick_B View Post
    I am modifying my lathe just a little bit added C indexing. Need to add live tooling for off center drilling , tapping and side drilling for some products I am making.
    Nov 2019
    21
    Quote Originally Posted by Warrrenkcash View Post
    Lucky Patcher Kodi nox
  1. Multifix Lathe Tool Holders from Createtool
    By datac in forum Uncategorised MetalWorking Machines
    Last Post: 12-31-2015, 06:33 AM
  2. WTB: Indexable Tool Holders Lathe.
    By Contract_Pilot in forum Want To Buy...Need help!
    Last Post: 07-04-2015, 09:14 AM
  3. Two tool holders for lathe
    By alex_ku in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-03-2013, 01:14 PM
  4. Tool holders for Daewoo lathe turret?
    By Chuck Reamer in forum CNC Tooling
    Last Post: 01-01-2008, 01:14 PM
  5. Tool Holders for a Lathe
    By javajesus in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2007, 05:11 PM
