603,923 active members*
2,504 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > PWM or TTL control of 15W chinese laser via bitsensor motion controller?
Threaded View
Selmer10S PWM or TTL control of 15W... 07-15-2019, 07:00 PM
Selmer10S To follow up on this, I was... 07-18-2019, 05:02 PM
Aubiwan Re: PWM or TTL control of 15W... 03-18-2020, 05:43 PM
Xnaron Re: PWM or TTL control of 15W... 07-18-2020, 04:10 AM
ZASto Re: PWM or TTL control of 15W... 07-18-2020, 01:18 PM
    Dec 2014
    Would need som help to figure out how to wire and get the laser control to work.
    My setup:
    Mach3
    BITSENSOR 4 Axis CNC MACH 3 USB Controller
    15W Blue Laser with 12VDC powersupply.
    Laser has the following connectors:
    [+ (+12V)] [ - (0V)] [PWM/TTL]
    [-] TTL/PWM [+]
    Bitsensor has the following pins for analog/PWM:
    [10V] [5V] [GND]
    [AVI ]
    [ACM]
    I have successfully got the 0-10V control to work when hooked up with a 10V supply to [+10V] [ACM] and [AVI] for the "signal" but I'm not sure how to wire it with the laser as there are several different voltages at play and no documentation available.
    Now I'm controlling the laser by shorting the [-] TTL/PWM [+] pins with a relay (NC) controlled by an output.
    Would be gratefull for any help with this.
    Attached Thumbnails Attached Thumbnails Bitsensor.jpg   Laser driver board.jpg
