586,102 active members*
2,721 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Need a way to copy KFlop flash memory to create a duplicate board
    Aug 2015
    I've got a K2 cnc running the KMotion / KFlop control system that is currently working just fine. My concern is that with K2 out of business, I would like to have a backup KFlop board in case anything happens to the first. The original files that K2 sent with the machine are not the ones that are flashed to the KFlop so they can't be used to recover the board. My machine was one of the first few to use KMotion and includes auto tool change and a dust hood gate that make it unique.
    My question is, is there any way to read and copy the flash memory from one KFlop board to another?
    May 2006
    4045
    Re: Need a way to copy KFlop flash memory to create a duplicate board
    Hi raasco_alan,
    We don't have a method of transferring programs without the source.
    I suppose you could write a program to write out the Thread memory spaces as binary bytes then read them back in on the other board.
    (From PC_DSP.h)
    Code:
    #define USER_PROG_ADDRESS_KFLOP 0x80050000  // where first user program is loaded
    #define MAX_USER_PROG_SIZE_KFLOP 0x10000    // space between each thread/user program
    #define N_USER_THREADS 7              // how many user programs/threads there are
    I think you would need to also copy the persist structure that contains UserData, Program EntryPoints, and RunOnStartUp:
    (From KMotionDef.h)
    Code:
    #define N_USER_DATA_VARS 200
    typedef struct
        int RunOnStartUp; // word Bits 1-7 selects which threads to execute on startup
        unsigned int EntryPoints[N_USER_THREADS];   // each downloaded program's entry point
        int UserData[N_USER_DATA_VARS]; // General purpose way to share and or save user program data
    } PERSIST;
    extern PERSIST persist;
    TK
    http://dynomotion.com
  1. Replies: 1
    Last Post: 12-17-2016, 05:17 PM
  2. i can`t copy a program fom USB memory to CNC
    By alain aleman in forum Fanuc
    Last Post: 06-10-2015, 11:45 PM
  3. How to create mold to copy existing items?
    By Jakobud in forum Moldmaking
    Last Post: 12-04-2010, 02:54 PM
  4. Can't copy ALL programs from memory to USB...
    By Mike Braddock in forum Haas Lathes
    Last Post: 03-23-2009, 04:42 PM
  5. USB flash memory as bootdisk
    By slp_prlzys in forum Computers / Desktops / Networking
    Last Post: 09-26-2004, 09:03 PM
