586,296 active members*
3,970 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Mazak M plus parameter?
    Jun 2007
    9
    Unhappy Mazak M plus parameter?
    Anyone know if it is possible to set a mazak parameter to 1/4 circle interpulation instead of 1/2 circle interpulation and if so what parameter is it .I seem to have either over looked it in the book or its not in the book.:idea:The machine is a mazatec FH-880.
    Feb 2006
    992
    You should able to do that... look under U parameter.
    The best way to learn is trial error.
    May 2007
    227
    can't you do that with the line machining?
    Jun 2007
    9
    Thanks for the reply.Any clue to what # on the U parameter?
    Feb 2006
    992
    One easy way to find what parameter for it is look under TPC, and whatever the retract is match...... blah blah then change parameter.
  1. Mazak T2 parameter input format?
    By nervis1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-25-2023, 04:39 AM
  2. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  3. parameter 64
    By swartling in forum Haas Mills
    Last Post: 02-20-2007, 11:57 PM
  4. Parameter changes
    By jorgehrr in forum G-Code Programing
    Last Post: 02-16-2007, 03:06 AM
  5. Mazak OP2 parameter
    By xr135 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 08:11 PM
