586,115 active members*
3,516 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Festo Pnuematics- I'm baffled!!
    Sep 2007
    28
    We have a machine dedicated to measuring length of product and it utilizes a complex series of rollers and cylinders for routing of the material- all of that is fairly irrelevant in regards to why I'm posting. The particular Festo unit, VPPM-6TA-L-1-F-OL10H-S1, is good for up to 10 bar according to the datasheet. The valves equipped with this are capable of being manually actuated but when this is attempted we received no pressure through the valves. Initial pressure was 6 bar, far below the stated max. We were unable to manually or electronically actuate the valves until the main inlet pressure was reduced to 4 bar. There were no faults on the Festo unit as it is equipped with an LED fault indicator. I have never encountered a valve that has manual override functions for actuating not work based upon system pressure. Any insight would be greatly appreciated. The machine is currently functioning properly so there is no rush or immediate need but a better understanding of this would be great. Thanks in advance for any info you can offer.
    Dec 2013
    5717
    Re: Festo Pnuematics- I'm baffled!!
    Could be an internal leak in the pilot. That would be my best guess.
    Jim Dawson
    Sandy, Oregon, USA
  1. I need Festo Didactic Lab Volt CNC Lathe or Mill software
    By Shelby5041 in forum Want To Buy...Need help!
    Last Post: 09-04-2019, 11:57 PM
  2. Festo cylinder on bandsaw
    By EricBear in forum Australia, New Zealand Club House
    Last Post: 11-15-2011, 11:36 AM
  3. Moving part using hydraulics or pnuematics
    By DerbyCountyFan in forum MetalWork Discussion
    Last Post: 05-02-2010, 11:09 PM
  4. Baffled with Limit & Home switches and BOB
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 05-22-2009, 01:27 AM
  5. Baffled
    By meflis in forum DIY CNC Router Table Machines
    Last Post: 01-11-2009, 04:00 PM
