586,753 active members*
7,216 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Torque limiter for tapping
Results 1 to 6 of 6
    I am looking for a torque limiter to place in the tailstock and hold a chuck that in turn holds a regular tap.
    I sometimes use an electrical handheld drill for tapping and the adjustable torque is great. I want that feature in a tailstock setting.
    Where can I buy one so I do not have to make it?
    Dec 2013
    5717
    Re: Torque limiter for tapping
    Jim Dawson
    Sandy, Oregon, USA
    Thank you.
    That is the function that I am looking for but hoping ti will fit the tail stock chuck and/or used also in a vertical milling machine
    Dec 2013
    5717
    You don't give any specs on the tailstock so it's a bit hard to offer holder advice. Maybe this? https://www.amazon.com/MT3-ER32-Mill.../dp/B00RN38KPO
    for the mill https://www.amazon.com/Thread-Collet...79&s=hi&sr=1-3
    Jim Dawson
    Sandy, Oregon, USA
    Sorry Jim,
    I am looking for something like the front end of an electric drill with an easily adjustable torque setting. This is not for production work, just hobby stuff.
    What I envision is a 10mm=3/8" chuck to hold taps and the other end is a 10mm=3/8" rod that would fit the lathe or mill or drillpress chuck.
    I have been thinking of cannibalize an old electric drill. I do power tapping now but I have to be very careful to stop in time.
    Dec 2013
    5717
    You may have to cannibalize an electric drill. I've not seen anything like that.
    Jim Dawson
    Sandy, Oregon, USA
  1. Quest 8/51 1053 e torque limiter fault wont reset
    By bschris in forum Hardinge Lathes
    Last Post: 10-19-2017, 12:26 PM
  2. Fadal vmc 15 tapping torque
    By Welder2022 in forum Fadal
    Last Post: 09-18-2016, 03:30 PM
  3. synchronized tapping torque monitoring
    By dec11ad in forum Okuma
    Last Post: 02-26-2015, 06:34 PM
  4. E Torque Limiter Fault, Error 1053
    By toolloon in forum Hardinge Lathes
    Last Post: 02-23-2012, 05:26 PM
  5. Puma 10S torque limiter alarm question
    By fv74 in forum Daewoo/Doosan
    Last Post: 05-11-2007, 09:13 AM
