603,942 active members*
3,334 visitors online*
Results 1 to 8 of 8
Hybrid View
Prolightman can someone describe serial... 06-09-2007, 06:18 PM
Al_The_Man Without further info on the... 06-09-2007, 07:14 PM
JEST Sounds like a vending machine... 06-09-2007, 09:36 PM
Prolightman thats My guess (CLAW... 06-10-2007, 06:28 PM
JEST Could be used for 2d or 2.5d... 06-10-2007, 07:24 PM
    Mar 2006
    21
    can someone describe serial input
    heres the thing
    I found a 4 axes controller as salvage yard(new in box)
    it uses serial input to communicate
    there was no software theres no silkscreen info on board
    (proto-type) said claw machine
    how does a serial based controller get data from computer
    are they all different codes??
    24260
    Without further info on the actual board it is just guess work.
    But typically motion cards, wether in a PC slot or stand-alone use some kind of RS232 terminal program to download individual commands or complete programs.
    Of course the command instruction set has to be known and what is required as to the RS232 protocol.
    Some board manuf. will supply a suitable interface program, and many will allow any modem program to work, like Win-Terminal, Qmodem, ProCom etc.
    Al.
    Albert E.
    Nov 2006
    227
    Sounds like a vending machine "crane" (claw machine) control.
    X axis
    Y axis
    Up/Down
    Open/Close
    Google for info that direction.
    Mar 2006
    21
    thats My guess (CLAW MACHINE)with some looking around
    this is an all in one has steppers drives built in
    2 serial outputs inputs?
    I looked that up,they are out of business or have been bought out buy some company in main,
    theres a pic processor on in can't make out the numbers
    another for for the trash
    Nov 2006
    227
    Could be used for 2d or 2.5d applications. Use drivers for the XY functions, use the relay functions to raise and lower the Z axis. May not be suitable for a big project, but usefull for small items or engraving.
    Mar 2006
    21
    yes I'm going to go on a limb
    and agree this is direct input from open close contacts
    so the best I could do is make a parallel adapter
    was hoping for someone with knowledge of common serial interface protocols
    thank you all
  1. Need some help with Ethernet-to-serial
    By kingneutron in forum Computers / Desktops / Networking
    Last Post: 11-29-2006, 08:49 PM
  2. Serial 9 pin to USB adapter
    By 2_jammer in forum DNC Problems and Solutions
    Last Post: 03-20-2006, 08:33 PM
  3. Serial cable help
    By turbo_todd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2005, 03:52 PM
  4. Parallel to Serial
    By cbcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-09-2005, 04:21 PM
  5. Serial CNC Software?
    By Ian Cunningham in forum Uncategorised CAM Discussion
    Last Post: 08-02-2005, 02:18 PM
