586,077 active members*
3,815 visitors online*
    Sep 2009
    135
    Poor surface finish
    The images below show the issue I am having. This is on a TorqCut22. When traveling in the X direction there are heavy/deep tool marks in the part. Both directions were cut with the same conditions. When I interpolate a circle the pattern shows all the way around.
    Any suggestion on which component is bad. I am thinking that the Y screw/nut combination might be bad.
    X Axis travel direction
    Attachment 425340
    Y Axis travel direction
    Attachment 425342
    Jan 2018
    1516
    Re: Poor surface finish
    Looks like my Sieg X2 does.
    Mines mostly down to a wobbly screw rocking the table which you can only really see if you run a DTI across the back of it.
    I should never have used thrust bearings on those damn things.
    Not worth fixing mine though as my head gib ways have spread, head vibrations are making it look even worse.
    May 2016
    526
    Have you checked the ballscrew and thrust bearings as you appear to have some play in the screws
    Have you tried changing the side you approach from and changing from climb to push milling
    Sep 2009
    135
    I agree. I am not sure which one would be causing it though.
    May 2016
    526
    Quote Originally Posted by cooperjm View Post
    Id put a clock on the bearing and see if any play
    Sorry only just seen your reply easiest thing is to private message me
  1. Hobbymat md65 poor surface finish
    By dfox1787 in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2019, 04:54 PM
  2. Poor surface finish maching black delrin
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 04-25-2013, 05:17 PM
  3. Poor Surface finish on interior corners
    By metalmansteve in forum Mastercam
    Last Post: 09-26-2012, 09:18 AM
  4. poor surface finish
    By sinha_nsit in forum CNC Tooling
    Last Post: 02-17-2010, 04:48 AM
  5. Poor surface finish
    By pmsmichelle in forum Mastercam
    Last Post: 02-05-2010, 03:54 PM
