603,785 active members*
17,761 visitors online*
IndustryArena Forum > CAM Software > Mastercam > importing files to MC?
Results 1 to 10 of 10
Hybrid View
    May 2007
    327
    what is the best file type to import from IGS? DXF? etc
    Sep 2003
    35
    I have always had good luck with IGES, but just always remember that converting a file from one to another is like translate japanese to norwegian, many times something will be lost in translation.
    Lars
    202
    I use parisolid for most my importing. I beleive parisolid is very clean import.
    May 2007
    327
    rgr thanks!
    here is a really dumb question. after you drop a 2d line or rectangle or whatever is there a way to re-edit it? not meaning trim mean getting back into the ribbin bar or even better draggin the points again? no way to open it or redrag it again?
    ty
    Mar 2007
    168
    I have always had the best luck with parasolids when importing into MC. I have never had any issues with IGES either. IGES seems to be a more universaly used format (atleast with the companies I deal with). Either way will get the job done.
    Apr 2003
    3578
    Well what version of MC are you using and what software are you trying to get a file from this can make a diffrence?
    Cadcam
    Mar 2007
    168
    If I understand you correctly, you want to be able to change a 2D feature that you have already drawn much like you can on higher end modeling programs like unigraphics, IDEAS, ect... I have not tried Version 10, but up to version 9, no you can not to the best of my knowledge. You either have to be creative in MC using different tools such as extend-length, or the other xform and modify tools. Depending on what you have available to you, it is sometimes helpful to create as much geometry as possible in a more powerful modeling software. Again, I am unsure what V.10 has to offer, but as far as V.9 is concerned, i think that once you get comfortable with it, you will have no problem with the 2D and some light 3D Cad in MC.
    Apr 2003
    3578
    If you are asking aster making a rectangle and you get out of this function can you go back and make changes yes but you can not make it a like Eninty again like when you first made it, were it was blue color 11 and make easy changes.
    But if it is a solid Primitive block then yes.
    But you can edite the lines in the rectangle by using F4 you can change the info there.
    Cadcam
    May 2007
    327
    thanks thats the info I needed, had a feeling that was the case. Very odd that the option to drag and drop goes away after finishing a sketch.
    Mar 2007
    168
    WOW, I have been using MC heavily for years, and i never stummbled upon that option....That is great! Thanks for the great info!
  1. SolidCAM & Solidworks vs. MasterCAM
    By griffithbuilt in forum Uncategorised CAM Discussion
    Last Post: 07-03-2007, 06:46 PM
  2. MasterCam or SolidWorks ?
    By cijunet in forum Mastercam
    Last Post: 12-19-2006, 09:24 PM
  3. Replies: 9
    Last Post: 08-04-2006, 07:19 AM
  4. solidworks/ Mastercam witch one !!!!
    By craftech in forum Mastercam
    Last Post: 01-16-2005, 05:11 PM
  5. Add on to SolidWorks. New to the USA.
    By SolidCAM in forum News Announcements
    Last Post: 09-03-2003, 03:46 AM
