586,096 active members*
3,158 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Want to route text for labels
    Hi folks
    Hoping someone can help.
    I have purchased a Chinese CNC router 3018.
    This was purchased mainly for work, routing and later laser, (making plant ID labels for machinery and equipment)(text and numbers), and also for me to learn what is good and bad for my personal build.
    The unit come with its standard program, which works in sample demo.
    I will be working in Graffolite type material (2 layer plastic) and the idea is to engrave the text and then cut out the shape.
    I have loaded Inkscape to create the vectors and Unicorn for the G code files.
    It doesn't work.
    What free programs do you guys recommend to do this work?
    Am I going down the wrong path?
    I am looking for something simple so once running, the guys in the workshop can quickly do labels as required.
    Thanks for any help in advance, cheers, John
    Sep 2018
    20
    Re: Want to route text for labels
    Feralbass,
    Which control system is on you cnc ?
    Aug 2019
    7
    Quote Originally Posted by Feralbass View Post
    Hi folks
    It doesn't work.
    Hi John, the application software could be GBRL. Google it and have a try. Good luck.
  1. Reports and Labels in 2017
    By jkcreative in forum Alphacam
    Last Post: 01-20-2017, 03:50 PM
  2. Changing labels into RDworks
    By otromar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-19-2016, 02:46 PM
  3. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  4. Using labels in Edgecam
    By nigel2000 in forum EdgeCam
    Last Post: 03-26-2013, 10:32 PM
  5. Enroute Barcodes and Labels
    By Dave_Fusion in forum EnRoute
    Last Post: 03-05-2012, 05:57 PM
