586,096 active members*
3,721 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Chinese Spindle Stalling.. better vfd?
Page 1 of 2 12
Results 1 to 20 of 27
    Jul 2019
    24
    I purchased a 2.2kW 4 pole watercooled chinese spindle + Filing inverter, cutting a hardwood with a 1/2 2 flute @ 5-7mm doc 7mm stepover 2500mm/min 10k rpm the spindle would get dangerously slow to the point that it would stall if I didn't stop it.
    As it turns out the inverter was advertised as sensorless vector capable but that is only up to 60Hz..
    Cutting at 3mm doc with above settings the inverter pulls about 1.5A. Off the top of my head Gwizard calc estimated the required power to be approx 250w which I assumed it should be more than capable of at that rpm?
    My question is would a good quality (branded) vfd capable of open loop solve my problems?
    The spindle stayed quite cool to touch after 5 hours of cutting maybe 30 degrees on the outside jacket.
    Any help would be great thanks
    Re: Chinese Spindle Stalling.. better vfd?
    What's the current draw when it's stalling?
    Jul 2019
    24
    Not sure what the current is when it stalls but the most I've seen it get to is 1.8A @10k rpm usually about 1.1A. I've gone through all the settings and it's set to 10A and can't seem to find any other settings that could contribute..
    15362
    Quote Originally Posted by Ritzy321 View Post
    You have your Parameters set incorrect so don't run your spindle with these setting or you will smoke your spindle
    If you only have a 60Hz VFD which I doubt that you have, this will smoke your Spindle if it can only be set to 60Hz
    If you are able to get 10,000 RPM you are not using a 60Hz only VFD Drive
    Post what your VFD Drive spec's are model number photo
    Mactec54
    Jul 2019
    24
    The inverter is a DZB312B002.2L2DK and I managed to get it running properly. In the manual there is an inverter model type selection and this inverter needs to be set to a "2" which isn't listed as an option (see attached).
    Also had a reserved function which needed to be set to 1235..
    These manuals are a little bit cryptic
    Spindle cuts really nicely now.
    15362
    What reserved function where you able to add a number to
    Do you have a PDF of your manual
    Mactec54
    Jul 2019
    24
    Approximately 2 Amps at 10k rpm. does that seem right?
    I still feel it is somewhat under powered as kept increasing the width of cut until it would start to stall at 240w (assuming gwizard is correct ofc)
    see attached picture.
    Jul 2019
    24
    The Fuling manual they sent me is the same as the DZB200/300 series one
    15362
    You say it is 4 Pole what are the motor spec's
    Max RPM=
    Max Amps=
    Max HZ=
    Need a list of what VFD Parameters you have set
    Mactec54
    Sep 2005
    1740
    How do you know your running 10,000 RPM? Mactec54 knows VFD settings so listen to what he is asking.
    Jul 2019
    24
    Max RPM = 24000
    Max Amps = 8
    Max Hertz = 800
    Everything is reset to default (as per the sellers instructions)
    And then set
    F3.01=1235 - reserved function
    F0.04=800 - Max Freq
    F0.05=800 - Upper limit
    F1.02=800 - Motor rated freq
    F1.03=24000 - Motor rated speed
    F1.04=220 - Motor rated voltage
    F0.03=1 - VI freq command selection
    F0.01=0 - Terminal
    Inverter seems to default motor rated current to 8 Amp.
    I don't have a way of measuring the speed, only what the inverter tells me 24k/800Hz..
    15362
    Max RPM = 24000
    Max Amps = 8
    Max Hertz = 800
    And then set
    F0.01=0 - Terminal
    The seller is just that and would not really know how to setup your VFD Drive or what any of the numbers mean
    I don't know why you would of messed with this Parameter F3.01=1235 - reserved function
    What mode are you using Parameter F0.00= 0 Or 1 ????
    F0.06=100
    F0.07=800
    Once you have checked your motor Parameters are correct you can then Auto Tune to your motor see snip F1.11=1
    F1.01=2.2
    F1.02=800
    F1.03=24000
    F1.04=220
    F1.05=8 ( Or Your Motor Rated Amps )
    Mactec54
    Jul 2019
    24
    F0.06=100
    F0.07=800
    F1.01=2.2
    F1.02=800
    F1.03=24000
    F1.04=220
    F0.00 is 1
    Also set F0.06 to 100 and F0.07 to 800
    The seller told me that this inverter does not support auto tune as I can't change it from 0 and they also said that F0.00 = 0 is only for 50-60Hz motors even though it was advertised as sensorless vector capable..
    15362
    F0.00 is 1
    Sensorless vector without auto tune would be like buying a new car without wheels, they are telling you BS 50-60Hz is only for V/F I have heard a lot of Bs from sellers, this kind of tops the list
    The series 300 has Auto tune I have the different manuals Series 100 200 and 300
    You may have been sold a copy if it is the 300 series and does not have Auto Tune
    So set F0.00=0 and test run it to see if you have any improvement
    Mactec54
    Jul 2019
    24
    It only seems to spin very slowly won't change speed no matter what the frequency is.
    Also noticed it has DZB 215DK sticker on the inside, would that indicate a 200 series and maybe not a 300?
    15362
    That would make sense as it seems to be a 200 series drive which does not have Auto Tune, I would say you have a VFD Drive that is not suitable for the spindle you have, these drives are normally quite good
    If you need / buy a sensorless vector control than make sure the VFD has Auto Tune
    Do you have a web link from where you brought it from
    Mactec54
    Jul 2019
    24
    https://m.aliexpress.com/item/32985780664.html
    Thanks for your help, appreciate it.
    15362
    That is a good spindle brand name not used by many but I have used there spindles
    By there specs they have a minimum working speed of 12,000 so running it at 10,000 may have been some of your problem even though it can run at 10,000 it would not have very much torque at that speed by what there spec's are,I would say even though it is a 4 Pole it should have a lower speed
    I have one of there 2.2Kw 2 pole and it is good down to 3,000 up to 24,000
    It also has a 10A rating not 8A that you have set, it would have to be set at 10A in the VFD Drive, then it comes to the VFD Drive which may not suit your spindle when using single phase power as the VFD max output is 10A this should be at least 12A minimum, so the VFD Drive is borderline at best
    What is your Amperage for the 240v supply power to the VFD Drive
    Mactec54
    Jul 2019
    24
    I also have tried 12k and above rpm with not much difference, I have a 15A plug but didn't think running it at 8A would make a huge difference. I think I will just buy a new vfd anyway any brands you could recommend?
    15362
    Your VFD required needs to be larger than your spindle so 3Kw to 4Kw and rated for 800Hz or more
    I think you have a power supply problem to start with 15A supply is not going to run a 2.2Kw spindle
    You need a minimum 240v supply at 25A most have use 30A Circuit for the 2.2Kw spindle
    Can you post some photos of the wiring, you may not have a VFD Drive Problem
    Mactec54
Page 1 of 2 12
  1. Chinese CNC stepper motor stalling
    By canman77 in forum Stepper Motors / Drives
    Last Post: 05-21-2019, 09:13 PM
  2. Chinese spindle with HY VFD stalling
    By Wallied in forum Spindles / VFD
    Last Post: 02-03-2019, 02:14 PM
  3. Chinese Spindle Stalling
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 10-23-2015, 01:56 PM
  4. Replies: 4
    Last Post: 03-01-2013, 07:19 AM
