586,082 active members*
3,563 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Usability of Encoder on DC Motor,
Page 1 of 2 12
Results 1 to 20 of 26
    Doing a retrofit of D&M 5 Lathe, adding Acorn CNC controller. It has the stock 90 vdc motor.
    Is it worth it to add a rotary encoder? Wondering if this will allow me to do threading?
    Also, any encoder recommendations would be appreciated.
    Thanks, Joey
    Sep 2006
    509
    Re: Usability of Encoder on DC Motor,
    definitely need an encoder to do proper threading. Normally I'd say on the spindle not the motor but from the looks of it you have a toothed belt drive so slipping is not likely - and if it does it will be obvious!
    The CUI's AMT programmable encoders (models 102 and 103) have been working for me, but might be tricky to install on your setup - needs a small shaft to go over. Readily available from lots of sources (I use Digikey).
    Trying to reuse the slotted disk will probably be more trouble than its worth.
    May 2013
    16
    I bought these from robotdigg for really cheap.
    https://www.robotdigg.com/product/13...per-revolution
    it comes with either a hollow or solid shaft. They also sell higher resolution encoders if needed.
    Mar 2017
    411
    The encoder will have to be on the shaft of the spindle and will need to have an Index signal. The index is what tells the controller where to start the threads.
    An encoder with an index and an A signal will work best. The index pulse tells the controller where the spindle zero degrees is and the A signal will produce a number of pulses for each revolution. The more pulses that A sends the more accurately the spindle RPM can be calculated by the controller. Thus making better threads.
    Here are several encoders.
    https://www.automationdirect.com/adc...otary_encoders
    Aug 2009
    230
    However, depending on the controller used, it could be possible to swamp the control with spindle pulses. Check your control's manual for a recommendation on the number of pulses per revolution of the spindle.
    Decided to go with this since I've read many people with Acorn boards have had success with it and acorn recommends 1000 ppr minimum
    https://www.automationdirect.com/adc.../trda-2e2500vd
    Acorn also requires 1:1 spindle to encoder ratio, with the limited space I'm working with and what looks to be an inability to mount a timing pulley directly to the spindle I'll essentially be duplicating the gearing ratio between the motor and spindle but it will turn the encoder instead.
    Ill be 3D printing all the pulleys and mounting brackets to get the alignment and tension correct then making some aluminum ones as a permanent solution.
    15362
    Quote Originally Posted by Joey2point0 View Post
    Thanks, Joey
    The Encoder would be geared to the spindle the motor is unimportant
    Tt seems like you have a lot of replies but nobody though to see what is suitable for your control
    Mactec54
    Mar 2015
    410
    If you have a 10 PPR encoder geared 1:10 to the spindle it has an encoder resolution of 100. If use this value, it should work. I guess what acorn means is that the resolution should be an integer number.
    I have made an 8 PPR encoder on the spindle back using 2 proximity switches, 8 magnets for the synchronization and 1 magnet for an index pulse. That works fine, even on my low torque variable speed lathes. The synchronization error overall is less than 0.05 mm and about 0.01 mm during the final shallow passes.
    If your spindle speed is reduced by gears, the spindle speed won't change very much during threading and you only need a few synchronization pulse to produce a good quality thread.
    15362
    Quote Originally Posted by hfjbuis View Post
    I'm not sure what your point is his Control has a requirement, and a low count Encoder like you describe is a waste of time, for anything to do with machining, the more PPR the reaction and smoothness is what counts
    Mactec54
    Here is what I plan on doing, the motor/encoder ratio is the same as the motor/spindle ratio. I don't see why this wouldn't work, though I'm open to suggestions as this is my first time doing anything of the sorts.
    PS for mocking up purposes everything is 3D printed from PLA but once i settle on a configuration ill be printing them solidly out of Nylon
    Aug 2009
    230
    You would think that... (for that matter, I used to think that)... however, I've seen YouTube videos of people with converted mini-lathes doing threading with just one pulse per spindle revolution. They then put a standard nut on the threaded part; and it fit. I'm guessing that the spindle drive motor (and associated inertia) kept the RPM from deviating enough to ruin the part. It's remarkable what some people accomplish with rather modest means...
    However, if I had the computational grunt in the control's processor; I'd obviously prefer more pulses-per-revolution than just one, though... the theoretical point of diminishing returns will depend on the thread being cut, machine resolution & accuracy, and what type of algorithm the control is using to drive the motors (non-isochronous step & direction; or isochronous PID update cycle; and what kind of math it's using internally).
    Mar 2015
    410
    @mactec54 I am sorry if I wasn't clear
    • Not the gearing of the encoder is important but the final pulses per spindle revolution is what counts
    • By design, threads have a lot of clearance. Trying to get this few hundreds of a mm clearance within 0.001 mm accurate will not make a better thread.
    • Even so, according to the measured accuracy, even using this low resolution encoder, the result is accurate, not a waist of time but a learning experience.
    • I agree on the X or Z axis, a decent encoder resolution is a must because it is used for positioning.
    By the way, for accurate threading, meaning even the last winding (deceleration of the Z-axis) is in spec, I use a stepper on the spindle.
    You wiz machinists are loosing me, appreciate all the good info though. Certainly learning a lot through this process!
    15362
    Thanks, Joey
    Yes that will work fine as long as you have the right Encoder, a lot seem to be using this Encoder which is on the low side but seems to work with the Acorn Control Omron E6B2-CWZ1X, they can be had for around $30 to $40
    Mactec54
    15362
    If you are only working at Hobby level then anything can work even just a single index pulse, it just the control he is using has a requirement which has to be met or it will not work
    Mactec54
    Sep 2006
    509
    Sounds like acorn have a problem with the index, in that can't be more than once per spindle rev, which would rule out fooling it with just the total pulses per spindle rev as calculated at the motor.
    Bummer, I would think thats something they could fix easily enough.
    You could still do it with an encoder on the motor, and an index pulse once per rev from the spindle, just more parts...
    15362
    Quote Originally Posted by ninefinger View Post
    There is nothing to fix
    Acorn does not have a problem with anything to do with Encoder input, the Encoder only needs to be on the spindle it can of cause be on both but is not needed unless you are using servos motors that need the own Encoder
    Mactec54
    With all this being said can someone tell me if the way I plan on setting this up genuinely wont work.
    The encoder is driven by the motor at the same rate as the spindle. (see the photo)
    Mar 2015
    410
    I have looked at this acorn video https://www.youtube.com/watch?v=Gk1T_9-7_4g (and some others) for connecting an encoder to the spindle. In this video, they require one encoder revolution for one spindle revolution and use an encoder with a lot of wires. On some forums there is a request for an index pulse, others talk about quadrature differential inputs. For me, as an electronics/software guy, I read the requirements as a quadrature encoder and index pulse and one index pulse per spindle revolution. This fulfills the "one encoder revolution for one spindle revolution"requirement and also a requirement for rigid tapping.
    Your encoder is a 5 Volt quadrature encoder (A/B outputs) with index pulse (Z output) . For me, this should work.
    You have to check the manual for your controller to be sure or ask acorn (centric)
    15362
    If you have a reasonable Encoder and index pulse /Z pulse is not needed or used, it makes for a slow and jerk operation, the whole objective is to have a synchronized spindle and X axes to operate as smooth as possible
    An index pules / Z pulse are normally used for homing a machine, and does not perform that well for synchronizing 2 axes
    Mactec54
Page 1 of 2 12
  1. Digitizing and usability
    By Dave Koehler in forum Centroid CNC Control Products
    Last Post: 06-25-2022, 06:58 AM
  2. Alphacam usability
    By rbest42 in forum Alphacam
    Last Post: 12-03-2016, 08:15 AM
  3. HOW TO CHANGE ACTIVE ENCODER FROM LINEAR SCALE TO MOTOR ENCODER IN SIEMENS 840D.
    By sandeepmb123 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-02-2014, 08:05 PM
  4. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
