586,096 active members*
3,704 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Help! CNC Coordinates and actual measurements do not match
    Sep 2019
    Thank you for reading. I have a problem and I have no idea how to fix it.
    I noticed that my CNC projects were smaller than what I had thought they would be. So, I decided to test it. I used the lower left corner as zero and then made the spindle drop at 10.25 inches (260.350mm). When the machine ran the G-Code, the machine dropped the spindle at an actual 8.25 inches.
    I measured the board I was carving (it's 10.25 inches) and put the spindle back at zero. I jogged the spindle to the opposite corner and read the coordinates in CNC USB Controller. It said it was at 327.0563 when it should be at 260.3500. 327.0563 is over 12 inches. I'm at a loss. Any advice would be appreciated.
    1227
    Re: Help! CNC Coordinates and actual measurements do not match
    I Know nothing about Planet CNC ,so treat these comments accordingly.I would suspect either calibration error (i.e. number of motor steps per mm) is incorrect or there is some mechanical slippage.Could be both.The discrepancy is close to 1.25 in both cases and I would be very curious about the other axes if they have identical steppers.
    Jun 2010
    4256
    What Routalot said.
    Cheers
    Roger
    May 2019
    28
    This link might help ...
    https://planet-cnc.com/how-to-setup-cnc/
  1. X and Y axis problem. DOES NOT MATCH THE ACTUAL LASER HEAD
    By car_bore in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-20-2022, 11:36 PM
  2. Physical coordinates don't match software
    By mymdb in forum G-Code Programing
    Last Post: 07-26-2015, 07:38 PM
  3. cannot get corel draw measurements to match
    By Stephanie2928 in forum Chinese Machines
    Last Post: 05-07-2015, 11:45 AM
  4. Need NM-200 Measurements
    By MRM RCModels in forum Novakon
    Last Post: 03-06-2012, 06:54 PM
