587,691 active members*
3,593 visitors online*
    Sep 2005
    1740
    FYI Spindle Info
    https://en.wikipedia.org/wiki/Variable-frequency_drive FYI A equipment ground has nothing to do with VFD missing a phase. Nor does not using Shielded cable. Zener Diodes are used for voltage regulation, IGBT are output transistors used on VFDs, welders and many more. If you need to spin start the spindle, sounds like a phase is missing. Simple things first, check power wiring from VFD connections to motor wire could be loose or broken.
    Nov 2003
    452
    Re: FYI Spindle Info
    I may buy one of these cheap replacement units:
    https://www.ebay.ca/itm/2-2KW-3HP-VF...torefresh=true
    I've checked the power wire from the VFD to the motor and its fine.
  1. Info on Spindle TV
    By Eatonbrayer in forum PlanetCNC
    Last Post: 04-17-2018, 12:37 PM
  2. Need info regarding the hsd 4.5 kw spindle
    By M.Abid in forum Techno CNC
    Last Post: 02-25-2014, 07:13 AM
  3. 6m spindle drive info
    By dave3431 in forum Fanuc
    Last Post: 08-28-2009, 04:49 PM
  4. Spindle tool info
    By BluegrassPicker in forum Fanuc
    Last Post: 05-13-2008, 02:46 AM
  5. HF spindle info..?
    By walter in forum Uncategorised MetalWorking Machines
    Last Post: 08-23-2004, 08:05 PM
