603,425 active members*
3,057 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Hardinge conquest t42 Fanuc 18T "B" code error
    Sep 2019
    10
    Hi, my Hardinge conquest t42 is with milling option but without "c" axis only spindle indexing and have to use "B" for programming but when try is always this error : 2029 B code error ( photo is attached) . Please help if you can.
    Oct 2019
    Re: Hardinge conquest t42 Fanuc 18T "B" code error
    I have had the same error time ago, I cleared with a service to the four cam cylinders, these are located at the crown spindle that stops the spindle they have inductive sensors that checks for in and out of the shaft cylinder, just clean and oil the cylinders and check for the movent it must go in and out whit the B code in the program or directly with the solenoid air valve for these cylinders on the back of the machine, do you have a backup for the cnc parmaters? I need a copy for my machine, can you share?
  1. error "3 too many digits" ? Conquest T42
    By shaggyd in forum Hardinge Lathes
    Last Post: 03-11-2019, 10:26 PM
  2. Fanuc Oi-MB "750" and "5136" error
    By emre2blue in forum Fanuc
    Last Post: 11-27-2017, 07:37 AM
  3. Fanuc 10tF 7 Segment Error Code "F"
    By glbreil in forum Fanuc
    Last Post: 07-06-2017, 12:56 PM
  4. K2 with kmotionCNC "G Code Error GCode Aborted"
    By Dimebag_cnc in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-28-2015, 08:59 PM
  5. Fagor error code " No Spindle Speed Value "
    By Hirro in forum Fagor Automation
    Last Post: 06-20-2013, 02:32 PM
