603,392 active members*
3,184 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Jun 2007
    37
    Cool problem motors not moving
    hi, cnc brothers
    I'm have a problem with my new build . i can't get my motors to turn , i do hear a high pitch sound coming from them but no movement, the DRO's in mach 3 does move. i'm pretty sure i hooked everything up right.i don't know what else to do. hoping you guys can help me out. i attach a pdf document with my settings ,maybe you guys can see something i'm missing ..thanks
    Jun 2007
    37
    Re: problem motors not moving
    Any help..
    Jan 2018
    1516
    Have you wired up the 'enbl +/-' on the drivers (enable) to the bob or left them disconnected?
    If you do have it connected you need to set up an enable pin.
    I'm guessing you have no physical estop connected correct?
    My problem when this happened was with my enable set wrongly to active high.
    Jan 2018
    1516
    If you have the 'step/dir' signal from bob going to the negative- connection side on drivers you need set active low.
    If connected to positive+ then set active high.
    If/when they eventually move but in wrong direction then check 'reversed' in the 'soft limits' page.
    Ideally need your wiring diagram that you followed.
    Jun 2007
    37
    Thanks dazp for replying, the enbl +/- are not connected and no I don't have a physical e-stop yet
    Jun 2007
    37
    The wiring I followed is for the c10 board with the kl-4030 here's the wiring, it's in PDF format
    Jan 2010
    77
    It's hard to help with so little info. That's why you get little response. There are way to many things that can be wrong. Does your board need a plugin? Everyone thinks they wired it correct, but if it doesn't work, start second guessing your wiring. One missed step or wire changes everything. If you post clear pics of your wiring, we migtht be able to help. The C10 is just a breakout board. How are you driving it? It is not a motion controller by itself.
    15362
    Quote Originally Posted by rick027 View Post
    Do you have the Estop connected with a Jumper it won't do anything without it connected
    Mactec54
    Jun 2007
    37
    When I started this post I added the info in PDF my whole setup from connectings to leadscrew , motors ect.
    Jun 2007
    37
    No e-stop just have it on pin 10 and set to active low
    Jun 2007
    37
    Kenrbass I'm using kl4030 drivers to run it
    15362
    It has to be connected at the Breakout Board with a Jumper or a E-Stop switch
    Mactec54
    Jun 2007
    37
    Mactec54, wouldn't the reset button on the screen be flashing
    15362
    No it would not, you are only fooling it in software, you can't fool the hardware
    Mactec54
    Jun 2007
    37
    Ok mactec54, what do you mean by jumping it
    15362
    You add a jumper wire where you would connect the E-Stop switch, for testing only it will work but is not safe to do when you have motors that could run wild
    Mactec54
    Jun 2007
    37
    Another thing I forgot to mention mactec54. If the e-stop is the issue, the dro's wouldn't move correct?
    - - - Updated - - -
    Ok I'll give that a shot..
    Jan 2018
    1516
    Edit: Maybe ignore me. Just read about the jumper (X7) swapping the 5v common around to pos. D'uh. (I assume you did that one)
    Manual. https://www.cnc4pc.com/productattach...wnload?id=1214
    Something has confused me a little here. Bear with.
    The board diagram says 5vg next to the driver outputs. This tells me that it is 5v neg out not pos and the driver outputs are pos not neg (common cathode or anode whichever way round.
    I have 2 diagrams here and BOTH are showing me that in fact the driver pins ie 1 & 2 go to pul/dir + (not neg) and the 5vg goes to pul/dir - (not pos). This will be active high (I think)
    https://www.cnc4pc.com/productattach...wnload?id=1120
    https://www.cnc4pc.com/productattach...wnload?id=1121
    Regards to the e-stop. You might need to just stick a bridging wire in there as it tells me it is nc connection.
    Edit: still looking around and again this shows pins 2 & 3 going to pos +
    https://www.cnc4pc.com/productattach...wnload?id=1215
    15362
    - - - Updated - - -
    The software will do what ever you tell it to you will have to reset the E-Stop in in your software once you have connected the E-Stop output
    Mactec54
    Jan 2010
    77
Page 1 of 2 12
  1. Help! Having trouble moving my motors
    By timbochung in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-25-2014, 08:34 PM
  2. Motors not moving (Geckos 202.)
    By stef_d in forum DIY CNC Router Table Machines
    Last Post: 08-23-2010, 07:07 AM
  3. Motors not moving
    By neric in forum DIY CNC Router Table Machines
    Last Post: 07-27-2010, 10:58 AM
  4. Mach3 not moving motors
    By jasper371 in forum Mach Mill
    Last Post: 06-15-2009, 10:32 PM
  5. Motors not moving
    By lamicron in forum Mach Mill
    Last Post: 05-20-2008, 01:54 AM
