586,108 active members*
3,267 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Building CNC Control Panels to Comply with NEC and NFPA 79
    Sep 2005
    1740
    There has been some discussion on here about power sources, grounding and wiring control panels. NEC Section 670 (675) covers the Industrial Machine area pretty well, also the Code requirements for Grounding and wire sizing also applies to any panel built.
    NFPA 79 is a guideline for panel builders and its not mandatory except to comply with OSHA.
    This is a good place to start with NFPA 79, unless you want to purchase the 2018 Edition which is $65.
    Link to Siemens white paper for reference > https://assets.new.siemens.com/sieme...per-icp-us.pdf
    also > National Electrical Code Top Ten Tips: Article 409, Industrial Control Panels
    Or > https://library.e.abb.com/public/1b9...2yRbGpy34tjMzM
    Attached Thumbnails Attached Thumbnails Screen Shot 2019-10-06 at 5.23.23 PM.png
    24221
    Re: Building CNC Control Panels to Comply with NEC and NFPA 79
    There is an older version of NFPA79 in PDF out there, it may be still available.
    Al.
    Albert E.
    Feb 2009
    6028
    UL508A is also another good source for panel code, It goes through the SCCR requirements/calculations and when and where it's needed.
  1. Which Industrial Standard to Use (NFPA, ANSI, ISO?)
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 10-08-2013, 09:02 PM
  2. American Rotary Control Panels?
    By sortafast in forum Phase Converters
    Last Post: 08-29-2013, 08:47 PM
  3. Replies: 0
    Last Post: 12-10-2012, 05:05 PM
  4. Control Panels - Getting Started
    By minium in forum Engraving Machines
    Last Post: 09-05-2012, 04:43 PM
  5. Looking for MN Machinist to make 2x control panels
    By Zero Cool in forum Employment Opportunity
    Last Post: 08-20-2010, 08:08 PM
