586,408 active members*
2,886 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Inverter + Next Wave Automation CNC
    Oct 2019
    O.k., I've got a 2.2 Kw inverter and a Piranha XL controller, is there any way to enable spindle on/off ?
    I am not afraid to open the case of the controller, nor am I afraid to do some soldering, if I have to.
    Any help would be GREATLY appreciated.
    15362
    Re: Huanyang Inverter + Next Wave Automation CNC
    Quote Originally Posted by madmaxh3 View Post
    After looking up what you have contact the manufacture
    Mactec54
    Oct 2019
    mactec54,
    I believe I know the correct parameters for the VFD. Attached are three photos of the BOB (not pro quality, sorry).
    15362
    mactec54,
    The next wave I believe is a bad idea, you need a Relay to switch FOR and DCM on the VFD Drive if the Next wave has a spare output that could turn a Relay On /Off that is all you need I don't see a Relay on there Board
    It's just a switch with no voltage on the Relay output
    Mactec54
    Oct 2019
    Thanks mactec54,
    I think I have a relay that will work, I'll check it out.
  1. huanyang inverter HY020223B 3hp 2.2kw
    By holder1944 in forum Phase Converters
    Last Post: 07-17-2013, 03:14 PM
  2. 220V in to Huanyang Inverter
    By Jerry In Maine in forum DIY CNC Router Table Machines
    Last Post: 04-13-2013, 01:43 AM
  3. Huanyang Inverter Problem
    By icanoe in forum Community Club House
    Last Post: 03-15-2013, 01:35 PM
  4. huanyang inverter burn
    By edgas10 in forum CNC Machine Related Electronics
    Last Post: 07-02-2012, 06:42 PM
  5. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
