586,116 active members*
3,354 visitors online*
    Nov 2017
    4
    Roland PNC-5000
    Hi Guys
    My Vinyl Cutter Roland PNC-5000 has recently all of a sudden just stopped moving.
    The Stepper motor on the belt (cutting head) makes a buzzing noise whether there's a load on it or not which means the carriage doesn't move at all now. I'm hoping it's not a problem from the circuit board side.
    does anyone know what might be the issue please? I've attached a video too.
    Many Thanks
    Apr 2004
    5737
    Re: Roland PNC-5000
    If it's buzzing, it probably is getting the signal to move, but can't. Since stepper motors themselves rarely go bad, I'd check for mechanical problems first; see if the axis in question moves freely when powered down.
    Andrew Werby
    Website
    Nov 2017
    4
    Quote Originally Posted by awerby View Post
    Swapped it with another motor. Same thing again. Looks like it's the circuit board side just wondering what it could be. Like it's got holding torque.
  1. Retrofit Prolight 5000 (Benchman 5000) to run Mach
    By Impyman18 in forum Benchtop Machines
    Last Post: 07-10-2019, 04:12 AM
  2. Replies: 1
    Last Post: 12-29-2018, 05:37 PM
  3. OSP 5000 blanks out
    By DouglasR in forum Okuma
    Last Post: 10-05-2017, 01:03 PM
  4. Benchman 5000
    By machbuilder in forum Benchtop Machines
    Last Post: 09-01-2006, 01:04 PM
