586,052 active members*
3,972 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Can't get camera to show in TNG under Linux/Ubuntu
    Jan 2017
    Hello.
    I have been using my CNC router for a while without any issues.
    Now I wanted to add a USB camera that used to work with USB CNC under windows in the past.
    The USB camera works with Ubuntu built in Cheese app but when I try to locate anything related to camera in TNG, it is not there.
    I am using the newest TNG V2 but I also tried the previous version that is still installed in Ubuntu and the same behavior.
    I also tried another (different and cheap) USB webcam with the same result.
    Any suggestions?
    Thanks.
    Mar 2017
    1312
    Re: Can't get camera to show in TNG under Linux/Ubuntu
    Unfortunately camera does not work in Linux. Doing this on Linux is tricky due to different distributions. However this is on TODO list.
    Jan 2017
    Thank you for the answer. I was just about to install the TNG V2 on raspberry Pi 4 with Debian on it to see if camera would show up.
    Just to be clear, the CAMERA does not work on any Linux based distribution as of now?
    I was just saving money for the wireless MPG and now I have to buy a copy of Windows
    :violin:
    Mar 2017
    1312
    You can use any camera viewer. Yes, one build in TNG is fancy but you can get most functionalities from external camera viewer. Until I learn how to implement camera in Linux.
    TNG works great on RPi 4 and Raspbian. I do recommend good cooling because RPi 4 gets quite hot.
  1. using linux ubuntu to dnc or upload files to fanuc 21i-TA
    By ShawJohn in forum USB, RS232, PARALLEL etc
    Last Post: 10-26-2017, 11:47 PM
  2. DNC for Linux Ubuntu ?
    By Meccbell in forum OpenSource Software
    Last Post: 08-31-2010, 03:53 PM
  3. What DNC for Linux Ubuntu ?
    By Meccbell in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 10:37 AM
  4. Ubuntu & Linux EMC
    By pepperwood in forum LinuxCNC (formerly EMC2)
    Last Post: 01-16-2008, 10:41 AM
