586,416 active members*
3,367 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > I bought a Multicam 48 plus, I am having trouble with software.
    May 2017
    9
    I have just barely got this control to connect to my win xp pc with mx32 installed. Im not sure this control uses gcode, I dont even know what ucito or hpgl is. enroute? I suppose that is multicams cad cam package? My printed manual says version 3.01 I think the control is a 3.54 version,I will double check it tomorrow. Is this control worth fooling with? Or should I pull it and do a retrofit? I have cnc machinery with mostly fanuc controls. This is all new to me
    Dec 2013
    5717
    Re: I bought a Multicam 48 plus, I am having trouble with software.
    Fusion 360 has both MultiCam HPGL and MultiCam ISO posts. The HPGL is something I don't recognize as being able to run a machine and has a .plt extension, but the ISO is standard looking G-code with a .cnc extension. As I recall, Enroute will output either, been a while since I've worked with it.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2006
    118
    I run my MC Pro on MX32 using .plt files and have for years. I've used Enroute's plt PP, but the last 6 years or so I now use Vectric Aspire's "Multicam plt ATC" PP. Works great for me. Most Multicam controllers can read Gcodes also. I've attached a MC produce pdf of the controller acceptable G & M codes. This is an older pdf.
  1. Multicam M24-5 trouble shooting manual?
    By gpw123 in forum Multicam Machines
    Last Post: 09-25-2023, 02:45 PM
  2. MultiCam PPS Software
    By Albundy in forum Multicam Machines
    Last Post: 10-21-2021, 02:20 PM
  3. Software For Old Multicam, PSS
    By retske in forum Multicam Machines
    Last Post: 10-04-2017, 01:17 AM
  4. Just bought Practical Plasma table, which software to use?
    By Killerdub in forum Waterjet General Topics
    Last Post: 05-08-2010, 07:41 PM
  5. Has anyone bought this software yet?
    By Roger N in forum Vectric
    Last Post: 10-13-2005, 12:25 AM
