586,728 active members*
3,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > emergency stop condition after E stop
    Nov 2017
    23
    Hello guys,
    Maybe someone can help me, finally I succeed to take a big order and I have the first big problem after an E stop.
    The X axis is the only one with problem, if is ZY everythink works ok till I move on X.
    All this time the X axis moving really really slowly, even E stop is activated
    https://youtu.be/IEQCpxBJWVE
    Thanks in advance!
    24223
    Re: emergecy stop condition after E stop
    Sounds as though the controller is not seeing any feedback, or the feedback (encoder) date is wrong.
    What controller is this?
    I had a similar fault on a Fanuc 0 turned out to be a motor tuning parameter had somehow changed, or got corrupted somehow.
    Al
    Albert E.
    Nov 2017
    23
    Al
    Is a fatal 88hs. I move a little bit the resolver and machine run noW, i don't know for so long...Im scared
    A little. Is expensive to import in Europe. Like 300eur for delivery.
    Jan 2015
    417
    Sometimes but rarely the small coupling between the Resolver and Servo can break. If you back off the three screws holding the resolver and LIGHTLY pull on the resolver it should not come out. But you may have re-seated the molex connector on the resolver making a better connection and now it works
  1. Replies: 4
    Last Post: 03-10-2018, 07:37 PM
  2. Replies: 1
    Last Post: 01-09-2018, 10:40 PM
  3. HELP ME! Mazak alarm 207 EXT EMERGECY STOP
    By huutanthaco in forum Maintenance DIY Discussion
    Last Post: 02-26-2013, 04:18 PM
  4. Replies: 5
    Last Post: 12-31-2011, 02:29 AM
  5. EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 06:05 PM
