586,103 active members*
3,304 visitors online*
Results 1 to 9 of 9
    G31 not working
    hi all,
    i have a trouble with G31:
    NOT WORK
    G31X-20
    G31Y-20
    WORK FINE
    G31X20
    G31Y20
    G31Z20
    G31Z-20
    Jun 2010
    4256
    Re: G31 not working
    It does not help that you have provided next to no information about your setup.
    Since some G31 instructions do work for you, I don't think the problem is in the Mach SW.
    Do you have limits set up?
    Cheers
    Roger
    Re: G31 not working
    I am using a uc100 clone from usb to parallel using the mach3usb.dll on WIN10.
    Using directly on LPT and windows XP work GCODE G31!
    The machine is USB native and inside it has a PIC18F4550 chip the model of the card is a JP-382C.
    Is there a firmware for JP-382C with PIC18F4550 to make it work with mach3?
    In this way I could eliminate the clone UC100 USB / LPT converter.
    I want use the USB interface with windows 10 if possible.
    Thanks for your help.
    This is the problem:
    https://youtu.be/5rdCbcJC9oA
    Jun 2010
    4256
    Re: G31 not working
    Sorry, can't help with the UC100 side of things. I use an ESS myself.
    I do know that there is a problem with many LPT converters. Mach3 under XP uses the LPT port in ways a bit different from a printer, and many adapters cannot handle the extra features needed.
    Cheers
    Roger
    Jun 2015
    943
    Re: G31 not working
    Quote Originally Posted by DarkPhoinix View Post
    Get a real UC100 instead of a chinese fake one and your problem will be solved. (just my 2cents.)
    Re: G31 not working
    Almost all Chinese controllers have problems with probing.
    Re: G31 not working
    the probe work ! G31 is buged i am working to build a firmware for JP-382C with PIC18F4550.Need help for DLL for mach3
    Jun 2015
    943
    Re: G31 not working
    Ask the manufacturer.
    Re: G31 not working
    do you still have drivers for chinese uc100
    clone ?
  1. ATC not working...........
    By LSI Innovations in forum Tormach Personal CNC Mill
    Last Post: 01-07-2018, 08:30 PM
  2. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  3. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  4. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  5. Working with DWG's in MC X3
    By jewells in forum Mastercam
    Last Post: 09-03-2009, 03:32 PM
