586,117 active members*
3,606 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Frequency control by frequency
    Oct 2019
    11
    Hello
    I have an Altivar 12 2.2KW and I use the PlanetCNC CNC3 / 4 Controller USB Controller.
    https://www.se.com/ww/en/product/ATV...e-speed-drives
    My card can handle the speed of my spindle by the frequency which will avoid the addition of a card to switch from PWM to 0-10V.
    Is it possible with my Altivar 12 to control it by frequency?
    15362
    Re: Frequency control by frequency
    Quote Originally Posted by cedric087 View Post
    Hello
    No your VFD does not accept frequency for control and very few do
    You have PWM in your programing that should output the 0-10v you need
    Your VFD Drive can use Modbus or 0-5v and 0-10v to control the speed
    Make sure the VFD Drive has all your spindle spec Parameters set
    Mactec54
  1. logic trace 2018 frequency control of the points when tracing
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 09-30-2018, 09:40 PM
  2. Step frequency
    By Kestis in forum PlanetCNC
    Last Post: 01-12-2018, 04:21 AM
  3. Speed control using mains frequency driven Triac's
    By ceefna in forum Phase Converters
    Last Post: 01-26-2012, 01:33 AM
  4. Replies: 0
    Last Post: 02-10-2011, 03:05 PM
  5. Optoisolator max frequency
    By cnc kiwi in forum CNC Machine Related Electronics
    Last Post: 11-01-2008, 08:11 AM
