586,103 active members*
2,629 visitors online*
Thread: Cathode Wire
    Aug 2005
    58
    Cathode Wire
    Looking for a source or a specification for the cathode (negative?) wire which runs from the laser tube to the power supply. Insulation seems thicker than "typical" 300V wire but not as robust as the red wire. Can this side of the laser just use regular wiring?
    I am running a 100W RECI W4 with a HY-DY13 power supply.
    Mar 2007
    2083
    Re: Cathode Wire
    Is here no markings on the cable ?
    could it be like this Black Tri-rated Cable, 0.5 mm² CSA, 1 kV dc, 600 V ac
    https://uk.rs-online.com/web/p/tri-rated-cable/1805910/
    John
    PS
    or may be Farnell in US
    https://www.newark.com/w/c/cable-wir...0ac%20%20cable
    Aug 2005
    58
    Re: Cathode Wire
    Quote Originally Posted by john-100 View Post
    John
    PS
    Thank you, Man I feel dumb as this is so obvious. I should wear my glasses more often and maybe I would see that the smudges on the wire are actual specifications...
    Mar 2007
    2083
    Re: Cathode Wire
    been there my self
    some times the obvious is only obvious after some one points it out
    John
  1. Mitsubishi FX-10 1997, Problem with wire detection before the wire chopper.
    By Jeff247 in forum EDM Discussion General Topics
    Last Post: 10-29-2019, 03:26 PM
  2. Replies: 0
    Last Post: 02-08-2017, 02:24 PM
  3. Where do I connect the cathode on an anode only PSU?
    By coreman in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-06-2015, 10:45 PM
  4. USER MANUAL SODICK MARK X or XI wire EDM, and wire breakage
    By stan34 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2015, 03:56 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
