586,624 active members*
2,568 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad shuts down upon attempting to open a file
    Apr 2008
    6
    Please Help. Bobcad encounters an error and closes the program when I try to open a file. Running Windows 7 Professional. If I log in under a different user then it Works fine. Has anyone else experienced this problem?
    Mar 2012
    1570
    Re: Bobcad shuts down upon attempting to open a file
    Sounds like a read write issue.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2008
    6
    Any suggestions on how to fix it?
    Jun 2008
    1838
    If you are the "Administrator" for the PC/Network try removing the offending User and then either try re-creating that User Name or create a new one. Or have you tried setting BobCAD to "Run as Administrator" ??
    Regards
    Rob
    Apr 2008
    6
    Much Thanks to Al . He suggested to open file with merge instead of open and that worked!!! Now I tried to open with open and that worked too. Thanks again Hope this helps someone else too.
  1. Attempting to Make a Mold in BobCAD V26
    By fishinmachinist in forum BobCad-Cam
    Last Post: 02-29-2016, 04:27 PM
  2. Bobcad V23 won't open (running XP)
    By Fendbass22 in forum BobCad-Cam
    Last Post: 06-30-2010, 04:40 PM
  3. Bobcad V23 Won't Open
    By zachf in forum BobCad-Cam
    Last Post: 09-29-2009, 07:26 PM
  4. Open AutoCad .dwg File in Bobcad v.21?
    By Nat Wheatley in forum BobCad-Cam
    Last Post: 07-31-2009, 01:49 PM
  5. Bobcad Will Not Open.
    By Stampede in forum BobCad-Cam
    Last Post: 10-05-2008, 05:59 AM
