603,326 active members*
3,194 visitors online*
    Jul 2013
    77
    TRAUB TX7 serial connection
    I managed to read from the tx7 controller to PC via serial connection.
    But when i try to set the tx7 to accept incoming data from pc i have error 75 (tape recorder error).
    If i disable RTR from machine parameters (55:00001101) i don't get the error but it's doing nothing when i activate program input and send .nc file via DNC precision
    Sent from my SM-A705FN using Tapatalk
    Aug 2009
    1573
    Re: TRAUB TX7 serial connection
    maybe it needs a % sign at Beginning or just a Blank Line.
    Try to send the same Program back to CNC that you sent to the PC
    Jul 2013
    77
    I've tried to send the same program. But the tape error apears instantaneus after i pres the key combination. Maybe i need to make some other bridge in the DB25 connector to fool it that the tape player is OK. Or i dont know what could be the problem.
  1. SUDA2616 cnc serial connection - need help
    By miotom35 in forum Chinese Machines
    Last Post: 06-18-2016, 09:06 PM
  2. PLEASE HELP!! Serial connection to pc from 950 control
    By greatmagnet in forum Cincinnati CNC
    Last Post: 11-13-2012, 06:23 PM
  3. Serial connection
    By Mvu in forum Commercial CNC Wood Routers
    Last Post: 01-16-2010, 03:03 AM
  4. Retrieving TNC 145 via serial connection
    By A.A in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2009, 02:07 PM
