603,365 active members*
2,950 visitors online*
    Dec 2007
    61
    DMC 2143 and DMC 4143 compatibility
    My Camsoft program supports the DMC 2143 motion controller. I'm wondering if anyone has knowledge about using the DMC 4143 as a direct replacement. I have the Pro 15.9 version of Camsoft and would like an ethernet control. Any help would be appreciated.
    Apr 2003
    332
    Re: DMC 2143 and DMC 4143 compatibility
    Bobk,
    Yes, it is a direct replacement.
    The logic routines and commands in the CBK file as well as the operator interface and all wiring will remain the same.
    The 4143 motion box and the 2143 model have the same terminal connections just in different places on the motion board itself.
    Since you have a fairly older version of the software you will need to use the same computer and same Windows operating system. You will need to BACKUP the current CBK file then reinstall using the CamSoft installation CD to install and set up the 4143 series motion drivers. After this RESTORE The CBK file.
    Tech Support
    CamSoft Corp.
    [email protected]
    PH 951-674-8100
    Fax 951-674-3110
    CNC Controller, PC Based CNC Controls
    Dec 2007
    61
    Thank you for the info!
  1. Galil DMC-2143 - Red LED
    By LantonioA in forum CNC Machine Related Electronics
    Last Post: 04-19-2015, 02:44 AM
  2. Version 9 Pro OS COmpatibility
    By Bob La Londe in forum ViaCad / Shark
    Last Post: 01-29-2014, 11:47 AM
  3. 64 bit compatibility?
    By Teyber12 in forum Uncategorised CAD Discussion
    Last Post: 06-29-2010, 12:07 AM
  4. Cat 40 compatibility with BT 40
    By inertialabs in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2007, 12:53 AM
  5. Compatibility
    By elogicca in forum Open Source Controller Boards
    Last Post: 06-09-2006, 10:34 PM
