586,069 active members*
3,434 visitors online*
Results 1 to 12 of 12
    Apr 2019
    154
    Top 11 CNC Routers 2020!?
    The portal toolzview has recently published a ranking about the Best 11 CNC Routers in 2020.
    Here´s the list:
    1. Genmitsu CNC 3018 Router Kit
    2. Genmitsu CNC 3018-PRO Router Kit
    3. TopDirect 2500mw Laser Engraver CNC 3018 Pro Engraving Machine
    4. MYSWEETY DIY CNC 3018-PRO 3 Axis CNC Router Kit
    5. CNC Piranha FX
    6. Mostics CNC 3018 Pro with 5.5W laser module CNC Laser engraver
    7. Next Wave Automation CNC Piranha XL
    8. MYSWEETY DIY CNC Router Kits 1610 GRBL Control
    9. BobsCNC E3 CNC Router Engraver Kit
    10. BobsCNC E4 CNC Router Engraver Kit
    11. VEVOR CNC Router 3020T 3 Axis CNC Router Machine
    More about this and about the pros and cons of these machines you can find here:
    https://toolzview.com/best-cnc-routers/
    Do you agree to this ranking or do you have different opinions?
    May 2004
    210
    Re: Top 11 CNC Routers 2020!?
    A router with round linear rails and a 300mm x 180mm work area is the number one router for 2020? Are small size and most flex the criteria? At least it doesn't use a pirated version of mach3.
    Probably the most telling thing on their front page "When you buy through links on our site, we may earn an affiliate commission."
    Jun 2007
    3891
    You need to do some qualifying with that list up front, cause, none of those machines i would rate as "usable" let alone top. Maybe rename it "top toys you can buy to see if you want to buy a cnc router".
    Jun 2007
    3891
    Quote Originally Posted by philba View Post
    ah. i refused to click the link. makes sense now its spam for "buy this junk to make me money".
    May 2004
    210
    Quote Originally Posted by ihavenofish View Post
    Well, unusable is kind of a judgement term. One can do a number of things with those machines though it requires some care and experimentation. Slow and shallow is the name of the game with those low-end machines.
    Jun 2007
    3891
    Fair enough. But when i think "cnc router", i think that comes with a minimum qualification that those machines don't meet. These are more "desktop engraver" category.
    1227
    If they earn enough commission from the sales they may be able to buy a dictionary.On one of the pages devoted to the letter B they will find the word "best" ;I recommend that they read what it says.
    May 2005
    3920
    A good portion of the machines I never heard of before! That right there caused a bit of wonder as it sounded like an attempt to market new machines.
    As for desktop engraver, even here a well put together machine will beat a a flimsy piece of crap. Most of these machines can best be described as learning machines. What many learn is why did I waste money on this!
    May 2004
    210
    I'm about to hurl. CNC Zone Newsletter for February lists the toolzview article. Did who ever put that newsletter together actually look at the article and seriously consider the machines on their merits???The sad thing is people will see CNCZone as endorsing these machines as the 11 best when in reality, they really are close to the worst out there.
    Apr 2010
    6
    Makes me wonder, what would be cnczones top10 DIY projects
    May 2020
    A PC numerical control switch is a PC controlled slicing machine identified with the hand-held switch utilized for cutting different hard materials, for example, wood, composites, aluminum, steel, plastics, glass, and froths. I created a website about it and I also used wordpress theme detector on this website. It gives a great look for this website and also it will helpful for SEO purposes.
    Jun 2020
    Some great results to cover finished wood with epoxy resins, try one from our review.
  1. [TNGv2] - 2021-10-08
    By PlanetCNC in forum PlanetCNC
    Last Post: 10-11-2021, 08:17 PM
  2. PowerMill 2020 not working
    By zaman in forum PowerMILL
    Last Post: 09-02-2019, 01:15 PM
  3. 1.2020
    By Gallchobhair in forum UCCNC Control Software
    Last Post: 09-27-2016, 07:28 PM
  4. Vision Engravers & Routers New Large Format CNC Routers
    By CNC602 in forum News Announcements
    Last Post: 09-22-2009, 10:56 PM
  5. Rutex 2020 card
    By johnd in forum Servo Drives
    Last Post: 01-18-2008, 01:43 AM
