586,110 active members*
3,150 visitors online*
    Mar 2016
    11
    Mach3 Tool Table
    , John DiMarino <[email protected]> wrote:
    Up to now I have been cutting using contour for all my machining needs . I wanted to start using "V carve" instead . The CAM software (Carbide Create) request that I select a V Bit with either a 90° angle Tool #301 or a 60° angle Tool #302 which in this case is #302 and generated the Gcode (M6 T302) . After loading the Gcode into Mach 3 , I receive the following message.
    Selected Tool slot number too large, Block=M6 T302 Line 7
    My understanding is that in the Mach3 Tool Table slot number, is associated to the corresponding Tool Number. My question is, how do I add the Tool Number 301 to the Mach3 table when the maximum number of slots are 253.
    I greatly appreciate any assistance you can provide me with .
    John
    Re: Mach3 Tool Table
    Change the number in Carbide Create.
  1. How to have Mach3 use an Auto tool zero location on the table for Zero of tools.
    By jimskeet in forum Mach Wizards, Macros, & Addons
    Last Post: 01-24-2018, 02:01 PM
  2. Mach3 tool table and setting TTS tooling
    By Potatohead908 in forum Benchtop Machines
    Last Post: 11-30-2014, 09:56 PM
  3. Replies: 6
    Last Post: 10-08-2012, 05:26 AM
  4. Mach3 tools3.dat tool table binary file format exposed
    By gsnorcal in forum Mach Software (ArtSoft software)
    Last Post: 12-07-2011, 05:08 AM
  5. Mach3 tool table save / print ?
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-03-2010, 12:27 AM
