588,665 active members*
5,137 visitors online*
Thread: Air on fadal
    Feb 2006
    60
    Air on fadal
    My Fadal got a air/oil spindel. And every time that i run spindel it blow air on the back on the machine (near the chiller cabinet) thru vent.
    Does the air blow all the time, or only to remove water?
    Oct 2006
    143
    It sounds like it is stuck open.
    Don
    Aug 2005
    249
    The air/oil system turns on intermitedly (SP) when the spindle is off and will will turn on when the spindle turns on and then turn off a few minutes after the spindle turns off. The air/oil system vents to the atmosphere near the back of the machine. It sounds as though your machine is running fine.
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
    Jun 2007
    6
    yes our machines do the same thing. that is completely normal.
    Feb 2006
    60
    Thanks for reply.
    I put a tube on valve (improvised silencer), because it can get noisy, specialy when i need to listen a tool.
  1. nc fadal
    By fourperf in forum Fadal
    Last Post: 04-10-2013, 04:50 PM
  2. Fadal CNC 88 HS
    By oakie in forum Fanuc
    Last Post: 11-11-2011, 09:49 AM
  3. Replies: 4
    Last Post: 03-02-2006, 04:46 AM
  4. Fadal Emc
    By SLOWJOE in forum Fadal
    Last Post: 04-18-2005, 02:57 PM
  5. New Fadal
    By nervis1 in forum Fadal
    Last Post: 03-05-2004, 01:26 AM
