586,116 active members*
3,469 visitors online*
Results 1 to 8 of 8
    Jan 2020
    30watt fiber laser Chinese and Ezcad2
    Having issues resetting up the laser to work correctly after a windows 10 update last year. Manufacture is less then helpful. (no surprise there)
    1. 30watt chinese fiber laser with F-Theta F-330mm 1064nm len
    2. Board Model: LMCFIBER JXT-M40015 REV 20120321
    3. Ezcad2 software
    4. windows 10 32bit as I found out laser will not support the 64bit os.
    5. Will check all the solider joints as i'm still getting DOG message even with correct driver installed. (All of inside connectors are tight and joints are good in the welds)
    Other then that i have had this 6k unit on my desk for a year without being able to use it.
    I have the ability to remote someone in if there willing to give me a hand with this.
    Thank you,
    Steven
    Re: 30watt fiber laser Chinese and Ezcad2
    i'm using windows 10 x64 with EzCad2 2.14.11 , is it the drivers missing? i have the LMC4 Fiber + 60w raycus, and 110mm 185mm lense so can't help you with the cal much, i posted my settings just now on the other thread, but prob not much help.
    i am having same issue fiber laser windows 10 64 bit say demo mode
    demo mode means its not detecting the usb device, which likely means the drivers aren't installed, or 32 bit drivers on a 64 bit os.
    Aug 2020
    20
    According to the model number you mentioned, it seems like a copy controller. You can compare the original one with the copy one at https://www.chineselaser.com/
    Nov 2020
    i bought a BJJCZ marking board FBL1-B-LV4 , and i am stuck in demo mode. I tried windows 7 with no luck . Any advise or driver? Please help.
    May 2018
    35
    For LV4 Marking board,you only can use 2.14.11(lite) version EZCAD.You can find the software and driver in the link following.
    https://drive.google.com/file/d/1Cwg...ew?usp=sharing
    You need install drivers before open EZCAD.First uninstall your old driver then install this new driver to your computer.Following videos show that how to uninstall and install drivers.
    https://youtu.be/3_PnlOZsh7A
    https://youtu.be/R1ohAMcFWlw
    Aug 2021
    Had the same issue. Take the entire file including the "software key" off the USB drive and place it on the desktop. Once this is done make sure your laser is plugged in, the drivers are up to date in Device Manger. Then relaunch the software from the EXE file now on your desktop.
    Make sure you remove the USB drive (CD) that came with the laser. You may need to restart once.
    Also do not move the EXE file from the original location. You can create a shortcut but do not move any files out of the desktop folder.
