586,096 active members*
3,004 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Mills > Emco VMC-200 Alarm 911 (Emcotronic TM-02)
    Oct 2014
    Hi!
    I got the Alarm 911 and can't fix it.
    The switch to lubrication pump was tripped and has done so a couple of times, but when that happened i got an lubrication alarm.
    The 911 alarm is "Hydraulic thermal overload" and is an alarm for extra equipment,
    Doesn't sound like it has anything with the lube switch problem.
    Don't know what i should search for since the machine doesn't have any hydraulics in that i can find.
    attached scheme with lube pump, It was 1FH1.E1-Q1 that was tripped.
    Apr 2019
    Re: Emco VMC-200 Alarm 911 (Emcotronic TM-02)
    Hey, did you check the pressure switch? i have Emcotronic T2 electrobox parts for sale if you need something
