588,468 active members*
5,053 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Using steel instead of wood for construction
    Jun 2007
    4
    Smile Using steel instead of wood for construction
    What would happen if you took, say one of the medium size Solsylva-machines. And constructed the whole thing out of steel instead of wood? Using the same templates and dimensions etc.
    If I find a local metalworkshop with a lasercutter, I guess they could fabricate the parts for me without problems.
    Would you get a more solid machine, one that you could use for milling harder materials than a wood-built one? Or would you just end up with a heavier version of the same "weak" machine?
    Christian W.
    May 2006
    573
    Heavier version of a weak machine:-) Imagine the weight of this thing if you used the excact dimensions!! The gantry alone would proberly weigh atleast 100kilos:-) Steel is by no way a bad thing, im doing one made of lasercut parts myself at the moment, but the solsylva plans are for a machine easy to make using wood and common tools. If you want to make one of steel, make your own plans or look at the free mechmate, thats a sweet (and big) machine made up (mostly) of lasercut and bended plates.
    If you by harder materíal mean aluminium, proberly a steel one would be better, but dont count on milling things like steel or similar, there is a reason a real mill weighs as much as it does:-D If this is what you want, instead look at converting a small mill like the x3
  1. Milling Steel with a Retroed Wood Router
    By whiteriver in forum Commercial CNC Wood Routers
    Last Post: 01-21-2016, 06:15 PM
  2. help in construction!
    By drumbuilder in forum Wood Lathes / Mills
    Last Post: 01-28-2008, 02:43 PM
  3. Plans for steel construction?
    By AndyL in forum DIY CNC Router Table Machines
    Last Post: 03-19-2007, 11:57 PM
  4. construction plans
    By owhite in forum DIY CNC Router Table Machines
    Last Post: 01-19-2004, 05:07 PM
  5. I-Beam construction
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-14-2003, 06:18 AM
