587,511 active members*
3,307 visitors online*
    Dec 2004
    126
    boss V ram spindle swap?
    I have a boss 5 with a quick switch 200 splindle and just got a second boss mill but it has the erickson 30 quick switch, I would like to swap the erickson out for a QS 200 splindle.
    I have a spare QS200 from a manual J head machine. but does the boss take the same spindle as the manual mill?
    it looks like they use the same bearings, nut, etc but is the spline drive area the same?
    Duffy
    Sep 2004
    161
    I remember reading on this forum that each of the spindles were sized to fit the machine it was installed in. You may want to check the diameter / fit before you go too far. If the swap is going to lead to a sloppy spindle, you may want to reconsider.
    Nov 2004
    3028
    The CNC machines had a longer spindle shaft to accommodate the Z axis ball screw and nut assembly.
    Thus NO, the manual machine spindles will not fit the CNC and visa/versa.
    George
    15362
    Hi DD Machine
    The answer by Machintek is correct the Boss spindle is longer then the manual one by at least 6"
    Mactec54
    Dec 2004
    126
    thanks guys
    so it looks like I well be stuck buying 30 taper tooling.
  1. 110v single phase bridgeport motor swap
    By stanglou in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2011, 12:41 AM
  2. Controlling a Boss Spindle via VFD
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 08-27-2006, 03:40 PM
  3. Spindle concentricity on Boss 5
    By karlden in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2006, 08:08 AM
  4. Help with Boss 5 spindle motor
    By marco_54 in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2006, 11:57 PM
  5. Drawing swap
    By DLMACHINE in forum Rhino 3D
    Last Post: 12-20-2003, 02:30 AM
