586,076 active members*
3,737 visitors online*
    Mar 2006
    96
    Milltronics connection to computer.
    How do you connect a Milltronics Parter IV with Century IV controller to a computer? After installing a serial port card, and wiring 2 to 3 and 3 to 2, and ground to ground. Set port to 600 baud, 7, even, stop bits 2, parity none. What now?
    Apr 2004
    22
    What software are you using to send and receive programs with. Settng up the software would be the next step in setting up communications between your machine and the computer.
    Sean
    Mar 2007
    207
    Quote Originally Posted by Captain Midnigh View Post
    600 Baud will work, but sounds slow, especially if you will transferring big files. I have a Centurion V and I use 9600 Baud and have never had a problem.
    What Operating System is your computer using?
    John
    Mar 2006
    96
    Windows 95. Hyperterminal. 1200 doesn't work either. Century IV can't go to 9600. I need to test my serial port. How?
    Mar 2007
    207
    Serial port test
    I guess the simplest place to start is to verify that your terminal program is sending and receiving data.
    To do this, connect terminals 2 and 3 together on the DB-25 connector side of your cable. This will loop the PC output to the PC input. If you type on the keyboard you should see your characters echoed. If that works, your cable is probably good as well as the pc's serial port.
    If that works, I'd connect the machine back in and have it list a program out to the serial port and see if you get anything on the screen.
    John
  1. Buy new Milltronics or what else???
    By schrupphobel72 in forum Milltronics
    Last Post: 07-17-2007, 01:17 PM
  2. RS232 connection issues to Milltronics Partner V
    By Jeff S in forum Milltronics
    Last Post: 03-16-2007, 12:34 PM
  3. Parallel Port machine controller to computer connection HELP PLEASE!
    By whipsnade in forum DNC Problems and Solutions
    Last Post: 08-01-2006, 10:45 PM
  4. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
