586,117 active members*
3,566 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Lubrication for Hobby CNC Machine
    Question Lubrication for Hobby CNC Machine
    I have a DIY CNC router sporting 1605 ball screws, SBR16 round linear rails, and HGR15 profile rails. I would like to use a single grease for all of these if possible.
    This is not a high speed machine and not in continuous use.
    So after some research I'm looking at Mobilith SHC 220 grease. Is this a good choice? Should I go perhaps lower viscosity SHC 100? Or some other product?
    Re: Lubrication for Hobby CNC Machine
    Mobilux EP1 is cheap, and readily available. It's listed in the Hiwin Lubrication manual.
    Ah perfect.
    https://www.hiwin.com/pdf/lubricating_instructions.pdf
    For some reason some of my research steered me away from EP greases.
    Got to trust the manufacturer in this case.
    Thx!
    Apr 2015
    170
    I have always understood that EP or hypoid oils should never be used in gearboxes that used bronze or brass components because the additives can react badly with these metals, I assume this is true of greases as well. Dave
  1. Using pinch valves for cooling/lubrication circuit in machine tool
    By dragonkent in forum Uncategorised MetalWorking Machines
    Last Post: 05-03-2018, 08:52 PM
  2. what do you use for lubrication on your machine?
    By airbrush in forum Maintenance DIY Discussion
    Last Post: 02-24-2014, 01:20 AM
  3. new machine lubrication concept
    By Brucesu in forum News Announcements
    Last Post: 03-12-2011, 02:33 AM
  4. Machine tool spindle lubrication experiment
    By NC Cams in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2007, 04:55 PM
  5. Sino-nsh LV Lubrication Oil Recovery machine
    By sinonsh22 in forum News Announcements
    Last Post: 10-26-2006, 07:05 AM
