586,103 active members*
3,649 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > How do I tell the age of a FADAL 4020?
Results 1 to 9 of 9
    Oct 2006
    30
    I know this is a hard question to answer, but I am looking at buying a 4020 with CNC 88 control. The machine is at a warehouse and is an auction. The seller did not list the year of manufacture. Maybe the type of control will give a vintage? So I cant see it in person BUT has a money back guaranty that it will work with no charge to me to ship it back. It was supposed to be tested at the facility?
    I know very little about the Fadal but have used a HAAS. Is the 4020 CNC 88 upgradable? Dose it need to be upgraded? I am looking for a VMC to make custom hot rod parts and the VMC must be able to fit in my home garage. I have a ceiling 98" high and the door opening is 81" high. With a machine height of 97" high I could modify the ceiling if needed but the garage door can not be changed. So can I disassemble the machine to fit thru the garage door then reassemble it inside? How hard would this be to do?
    Thanks, Rick
    Feb 2007
    36
    the quickest way to tell the age is to look on the back. There is a tag with the serial number and date of manufacture.
    Oct 2006
    30
    Quote Originally Posted by drewmeister View Post
    That info is not posted. What year did FADAL upgrade the control from the FADAL 88?
    900
    In the old serial numbering system the first two digits are the year of manufacture. In the later numbering system the first two digits are the product code and the net four digits are the year of manufacture.
    Neal
    Apr 2005
    1194
    1992-back all had cnc88 controls. 1993 some had 88 controls and from 94-on they had 88hs, 32mp, 840d, legacy, 104d (watch out for this one) and lately its been fanuc. I think the 88hs is the better control. I really dont like the 88 controls.
    Not to mention once the 88hs controls came about the machines got ALOT better (1994). And in 1996 the servos went to AC IIRC:rainfro:
    Oct 2006
    30
    Quote Originally Posted by Neal View Post
    Neal
    How does this look?
    Model #: 906-1 / VMC 4020
    Serial #: 8810793
    Apr 2005
    1194
    That looks like a 1988 4020...worth less than 10K in any condition
    Oct 2006
    30
    Quote Originally Posted by carbidecraters View Post
    Thanky very much.
    Oct 2006
    143
    Quote Originally Posted by Rickady View Post
    Thanks, Rick
    I have the extended Z so this may not apply; but with mine the casting is taller than 81".
    HTH,
    Don
  1. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  2. 4th Axis for Fadal 4020
    By Fudd in forum Fadal
    Last Post: 07-23-2012, 09:49 PM
  3. Fadal 4020 For Sale
    By ltmquik in forum Fadal
    Last Post: 05-18-2007, 03:44 AM
  4. Fadal 4020 3d Contouring Problems
    By eric_99 in forum Fadal
    Last Post: 02-06-2007, 12:19 AM
  5. Fadal 4020 resurrection......
    By jnc in forum Fadal
    Last Post: 06-30-2004, 06:22 PM
