586,395 active members*
3,028 visitors online*
Results 1 to 8 of 8
    Mar 2012
    189
    threading issue
    I am in contact with tormach for help with this, but I was wondering if any of you came across this before? All my threads look like barbed fittings. The start end thread form looks more or less correct, but the back side looks like a different degree. Using iscar lay down inserts, tried a shars one too. same results from conversational or fusion. It did this on earlier versions of path pilot when I got the machine, but I didn't need threading at the moment and assumed user error. My thought is maybe the timing is not calibrated correctly? I verified z travel to be accurate to a known good indicator over 1.5".
    -Jon
    Feb 2011
    353
    Re: threading issue
    can you post your threading code ?
    Mar 2012
    189
    Re: threading issue
    (External Threading G-code generated: Mon Mar 30 15:55:07 2020 <v1>)
    (PathPilot Version: 2.4.3)
    (Description = externalThreading)
    (Material = Aluminum : -any-)
    (Units = G20 inches)
    (Work Offset = G54)
    (Tool Number = 6)
    (Tool Description = od groove thread)
    (Tool Type = rtp_part)
    (Tool Orientation = 6)
    (Tool Radius = 0.0158)
    (Spindle RPM = 400.0)
    (Z Start Location = 0.0000)
    (Z End Location = -0.3800)
    (Thread Specification = 1/2-13)
    (Thread Direction = Right Hand)
    (Inside Diameter = 0.4041)
    (Outside Diameter = 0.4985)
    (Taper [incl. lead in/out] = 0.0000)
    (Thread Length = 0.3800)
    (Pitch = 0.0769 inches/thread)
    (Threads per inch = 13.00)
    (Depth of Cut = 0.0403)
    (Thread Lead = 0.2)
    (Tool Clearance = 0.03)
    (Number of passes = 6)
    (Spring passes = 1)
    (Tool on X+ side)
    (Note: for 2 NPT External Thread)
    (Pipe OD = 2.375)
    ( for use with OD Turn and Chamfer)
    (Effective Thread Length = 0.7565)
    ( use as the distance between z_start and z_end in Chamfer)
    ( use an angle of 1.78 degrees)
    (----- Start of G-code -----)
    (<cv1>)
    G7 (Dia. Mode)
    G18 (XZ Plane)
    G90 (Absolute Distance Mode)
    G40 (Turn Cutter Compensation Off)
    G20 (units in inches)
    G54 (Work Offset)
    G30 Z #5422 (Park Tool)
    T0606
    G97 (RPM Mode On, CSS Off)
    S 400
    M8 (Coolant ON)
    M3 (Spindle ON, Forward)
    G0 X 0.5585
    G0 Z 0.2000
    G76 P 0.0769 Z -0.3800 I -0.0600 J 0.0403 R 2 K 0.0944 Q 30 D 0.0000 H 1
    G0 X 0.5585 Z 0.2000
    M9 (Coolant OFF)
    M5 (Spindle OFF)
    (</cv1>)
    (----- End of Thread -----)
    M30 (End of Program)
    -Jon
    Mar 2012
    189
    Re: threading issue
    did some more experimenting today. I swapped holders out to a dorian triangle on edge type and got good threads. I checked both holders and the tip of the insert is within a few thousandths of each other so I don't think it's a tool center height issue. I used the same program to run 5/8-11. part on top is the laydown iscar, bottom part is the on edge.
    Attachment 439622
    -Jon
    Jun 2006
    3063
    Re: threading issue
    Are you using a holder with a threading insert or some other sort of other insert type? External threading inserts usually look like this:
    https://tormach.com/11ela60-threadin...-lh-37288.html
    Mar 2012
    189
    Re: threading issue
    I think I figured it out. The inserts I bought off ebay and I believe they are not the part number on the package. I believe they are npt. once I swapped to different brand insert the threads worked out.
    -Jon
    Nov 2016
    62
    Re: threading issue
    Can we get a pic of the orginal insert?
    Also, on the Slant, I will program three spring passes (H3).
    Mar 2012
    189
    Re: threading issue
    supposed to be iscar 16er a 60 ic908
    Attachment 439752
    -Jon
  1. Threading issue
    By Janith in forum Fanuc
    Last Post: 10-07-2017, 07:08 AM
  2. sherline/deskcnc threading issue
    By erieworks in forum Mini Lathe
    Last Post: 06-02-2012, 01:01 AM
  3. Threading Issue with SL80
    By crow36 in forum Mori Seiki lathes
    Last Post: 10-20-2010, 08:41 PM
  4. Roll threading 2-56 look issue
    By nfs7713 in forum Haas Mills
    Last Post: 10-08-2009, 05:42 PM
