586,530 active members*
2,838 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > New Spindle drive (baldor)
    Jul 2007
    I replaced my Spindle drive on a 4020, and now the Fadal control will not start the spindle. I get a spindle drive fault motor overload error. I can run the spindle in Local mode from the keypad just fine. I have checked the wiring and everything is good. I have checked the parameters 4 times and everything is the same as the one I took out. I checked the spindle control card everything looks good there too. Any suggestions would be great.
    thanks Anthony
    4826
    What was the nature of the failure with the old drive?
    24223
    Sounds to me like the logic is wrong for the relay output from the VFD if this is where the OL is monitored from, some have NO as well as NC contacts for the relay outputs, it you have a separate OL on a contactor check it for trip.
    Find out where the Control gets the OL info from.
    Al.
    Albert E.
    Jul 2007
    I just found out that Fadal puts their own eproms on the drive, and just a Baldor drive off the shelf will not work. Got the right one coming now. Thanks for the help guys.
    Apr 2005
    108
    I think this eprom will not help you
    since there some changes in the boards of Baldor
    let me know if it worked
  1. Baldor Vector Drive Problems
    By ferroma in forum Fadal
    Last Post: 09-04-2018, 06:50 AM
  2. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  3. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
  4. Baldor Servos And Drive
    By Cycle Start in forum Servo Motors / Drives
    Last Post: 05-29-2007, 01:28 PM
  5. Baldor Vector Drive Problems
    By MetalTech in forum Fadal
    Last Post: 12-10-2005, 03:38 PM
