586,058 active members*
3,393 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > collete upgrade to shoptask 1720
    Apr 2015
    12
    i hope this post helps someone.
    i got tired of swapping out the mt3 tools on my 1720.
    i decided to try and upgrade to a collet system.
    none of the vendor out there seem to sell a kit.
    i ended up winging it
    as i so often do.
    so i bought an er32 mt3 m12 cheap collet set off of amazon.
    i then bought some m12 thread rod and an m12 nut for the drawbar.
    i welded the nut to the bar..the nut is an 18mm serrated flange nut.
    here are some pics
    runout was .0012
    no sure if thats good or not..im a novice..
    Attached Thumbnails Attached Thumbnails 20200502_115409.jpg   20200502_114100.jpg
    May 2016
    15
    Re: collete upgrade to shoptask 1720
    I picked up a similar set, but it's not answering the problem of short quill travel and working between short mills and longer drills and wigglers etc. Hard to work through a job without re-clamping the work at different heights.
    Sent from my SM-G950U using Tapatalk
  1. Looking for gearset for Shoptask XMTC 1720
    By jt69 in forum Shopmaster/Shoptask
    Last Post: 01-29-2012, 08:46 AM
  2. Shoptask 1720 XM TC W/CNC (W/Pic)
    By LX Kid in forum Shopmaster/Shoptask
    Last Post: 01-06-2012, 12:03 AM
  3. shoptask 1720 xmtx gold
    By turning in forum Shopmaster/Shoptask
    Last Post: 01-30-2011, 07:36 PM
  4. Shoptask 1720 XMTC add CNC
    By mustangdug in forum Shopmaster/Shoptask
    Last Post: 11-30-2010, 12:07 AM
  5. basic ?s on Shoptask 1720
    By laskaboots in forum MetalWork Discussion
    Last Post: 08-11-2007, 05:49 PM
